O2 sensor question for ITR knowledgeable people
Old Nov 6, 2003 | 12:28 PM
00ITR's Avatar
00ITR
i run a 00' ITR with many modifications and it seems to knock on 93/94 octane. So i run half premium and half 110 through it. I was wondering how much faster i will burn up O2 sensors if any and if i do is there a better one for this type of application. Any help is appreciated.. Thanks in advance...Ryan
Old Nov 6, 2003 | 01:25 PM
Jan Niemi's Avatar
Jan Niemi
Why is your motor knocking on 93 and 94 octane? Is your timing too advanced? Higher than stock compression? Or lack of tuning.
I assume you are using leaded 110 race fuel, this will contaminate the sensor quickly, you might delay it a bit by doing the mix you are talking about - but you shouldn't need 110 anyways unless you are running 12 to 1 compression or boost.
BTW, is this Canuck R by any chance
Old Nov 6, 2003 | 01:38 PM
Trey
Guest
Posts: n/a
turn back your timing and run 93 without knock
Old Nov 6, 2003 | 03:08 PM
00ITR's Avatar
00ITR
i think with the stage 3 cams and slightly milled head it is wise to run advance to avoid piston to valve hitting dont y ou
Old Nov 6, 2003 | 03:58 PM
Dave-ROR
Guest
Posts: n/a
retarding the timing via the distributor will cause this? news to me.
Old Nov 6, 2003 | 04:58 PM
Trey
Guest
Posts: n/a
Distributor timing as Dave has pointed out does not affect piston to valve cleanrance. What it is doing is causing your detonation.
What engine management are you runnning?
Old Nov 6, 2003 | 05:32 PM
Dave-ROR
Guest
Posts: n/a
just to be clear, we are talking about loosening and moving the distributor correct? I mean, changing IGNITION timing and not CAM timing right? :P
Old Nov 6, 2003 | 09:18 PM
Jan Niemi's Avatar
Jan Niemi
I don't know about these other geniuses, but I was referring to ignition timing.
Old Nov 7, 2003 | 03:24 AM
Trey
Guest
Posts: n/a
What other timimng is there that applys here? Distributor adjustment is ignition timing. Although it can be changed through a fuel management system worth a darn.
Old Nov 7, 2003 | 04:39 AM
Dave-ROR
Guest
Posts: n/a
Well, the guy who posted was probably thinking cam timing, that's why I was clearifying above. As for the guy's fuel management system.. here's my guesses "stock ecu + vafc", or "jun ecu" or "brand-x ecu with vafc"
In other words, not a system worth a darn.
