B16A
Old Aug 12, 2003 | 04:42 AM
e r i c s 9 9 s i's Avatar
e r i c s 9 9 s i
Both the JDM 1st and 2nd GEN b16's were stamped with the "B16A" on the block. However the 1st GEN b16's used cable trannies (S1/A1/J1/YS1) while the 2nd GEN b16's used hydrolic transmissions (SC4/Y21/S80/Y80). As far as specs go, the 1st gen b16a's were 10.2:1 motors in (90-91 Civic SiR/SiR II, 90-91 CRX SiR/SiR II, 90-93 Integra XSi) that made 160 hp @ 7600 111 lb-ft @ 7000 while the 2nd GEN motors were a 10.4:1 motor in (92-95 Civic SiR/SiR II, 92-96 CRX SiR/SiR II, 96+ Civic Vti, and 96+ Civic SiR/SiR II) that made 170 hp @ 7800 116 lb-ft @ 7300. The overall outside appearance is basically the same between the two motors, though the Intake Manifolds have a few less vacumm lines running off the IM than the USDM spec motors. My brother has a JDM B16A in his 94 civic coupe so I'll look at the head and intake manifold numbers on them and post them up for you... I think the head should be marked with "PR3-1" on the right frontal side of the head above the exhaust manifold.
As for the USDM motors, they've only made two different models which are the B16A2 that are found in the 99-00 Civic Si Coupes and the B16A3 that are in the 94-97 Del Sol VTEC's both motors were 10.2:1 CR and made 160 hp @ 7600 111 lb-ft @ 7000.
Hope this helps, if you need more specific information just let me know... I'll check out my brothers maybe tonight if I see him so I can post up all the numbers for ya.
Old Aug 12, 2003 | 06:29 AM
Dave-ROR
Guest
Posts: n/a
eric: All B16A heads will be PR3, but not all will be PR3-1 from my experience.
Other differences between 1st/2nd gen JDM motors include the color of the plugs, PGM-FI sticker not installed on the 2nd gen and some other stuff I can find again if you need it jan.
Old Aug 12, 2003 | 06:34 AM
e r i c s 9 9 s i
You're right about the upper (PGM-FI) sticker on the IM not being there on the 2nd gens... I have a few friends with different year JDM B16A's (1 CRX, 1 Coupe and 2 Hatches) so I'll see what the head codes are and there differences...
dawhiteboy: you can tell if the motor is a JDM vs. a USDM just by looking at the block code... JDM will say B16A and the USDM motors will say B16Ax (X being #2 or #3).
Old Aug 12, 2003 | 06:44 AM
Dave-ROR
Guest
Posts: n/a
I know. I said that in the second post in this thread
Old Aug 12, 2003 | 07:29 AM
e r i c s 9 9 s i
Mis-read that...opps ops:
