Interesting VAFC setting
Old Jun 1, 2003 | 02:06 PM
Jan Niemi's Avatar
Jan Niemi
I set the throttle setting to **, and the car seems to be smoother in transition from vacuum to boost. I still get a CEL once in a while under some circumstances, but having the fuel setting RPM dependent, rather than throttle angle dependent has made the programming a little simpler. Usually you have to set all of the maps, but under this setting you only set the WIDE map, and it carries over to NARROW as well..interesting.. :idea:
Old Jun 1, 2003 | 07:34 PM
Erik B's Avatar
Erik B
Kinda lost me on this one Jan...all I see is ** for your setting?
Old Jun 2, 2003 | 07:58 AM
Jan Niemi's Avatar
Jan Niemi
yeah, that's what the display shows when you don't select the throttle up/down arrow, it gives you ** (two asterisks) and then it ignores throttle percentage
Old Jun 2, 2003 | 01:12 PM
ITR41's Avatar
ITR41
mine won't go to the ** setting
Old Jun 4, 2003 | 08:09 AM
Jan Niemi's Avatar
Jan Niemi
It's in the car type menu where you select number of cylinders and tps type.
