vtec not working
Old May 4, 2003 | 04:22 PM
2000blacktyper's Avatar
2000blacktyper
my vtec isnt working and i dont know why. i just had to have a new block put in and when i got it back my vtec didnt work does anybody know why.
Old May 4, 2003 | 06:10 PM
Aj's Avatar
Aj
Have you checked your oil level???
Also, this new block, what type is it, cause if it's not Vtec, you need to run another line for the Vtec rockers to lock up...
You may also want to check and make sure that they remembered to plug in the Vtec solenoid as well as the pressure senders in back, if the one closest to the manifold isn't plugged in or loose, it won't give the ECU the ok to turn Vtec on cause it thinks you're oil pressure is too low.
One is a low pressure indicator, the other is for the Vtec I guess...not entirely sure, but I know if you switch them, then the Vtec won't work...They both look kinda like smurfs...ahhaha...or little black nipples, any way you want to look at it, try switching them and see what happens.
Later,
Aj
Old May 5, 2003 | 01:26 PM
2000blacktyper
i can only find one oil pressure sender. where are they located can you tell me exactly.
Old May 5, 2003 | 05:17 PM
Aj's Avatar
Aj
Just above that one below tha manifold, actually above the cooling vein I think, though i honestly dont remember...I didn't see it till I had the head off for the first time...
Later,
Aj
