What Type Of Coilovers are Everybody Using
Old Apr 8, 2003 | 05:54 PM
Type R 98's Avatar
Type R 98
i was personnally thinking billstein for street and track use in 2 years...
Old Apr 9, 2003 | 07:23 PM
JDMkalibeR's Avatar
JDMkalibeR
What do you guys think about the Mugen coilover systems?
Old Apr 9, 2003 | 10:18 PM
Aj's Avatar
Aj
Nice setup, but for the money there are at least a dozen others I'd get first, unless you're getting a really killer deal.
I think I actually saw a used set on www.aj-racing.com under their used section. pretty trick stuff....
Later,
Aj
Old Apr 10, 2003 | 09:30 AM
JDMkalibeR's Avatar
JDMkalibeR
have you guys seen the new RS*R coilovers... those are pretty sick.... pretty innovative. They were on display at the RS*R drift festival for those of you that went.
Old Apr 10, 2003 | 11:16 AM
Aj's Avatar
Aj
Got any pics?????
Old Apr 12, 2003 | 12:40 PM
descartesfool's Avatar
descartesfool
If you are interested in coil-overs with separately adjustable bump and rebound, there are two sets which are available below $2000 for the set. One is the Tein RS, and the other the Advance Design coil-over. I spoke to Greg at Tein USA and he said the Tein RS could be revalved/rebuilt in US for $160 ea., as long as they weren't struts as in MacPherson struts. The RS's have an external reservoir attached to the main body, with the adjustment for bump. The rebound adjuster is on the top of the main shock as it is for their models RA and RE. The external reservoir is similar to that of many more expensive dampers such as those by Moton and Leda. I also discussed with Greg the Tein N1, and found out that they were selling some for race cars, but these are about twice as stiff as the RS models. I found the Tein RS's priced at $1998 for the set at www.phase2motortrend.com.
I spoke to Jay Morris of Ground Control who builds the Advance design coil-overs. These can also be custom valved/rebuilt for only $50 ea. at their shop. They will build their threaded body coil-overs for any spring rate you want. There are two wheels at the top for bump and rebound adjustments. They supply Eibach springs at $55 ea. and also top spring mounts for $75 a pair I think. Coil-overs are $399 ea., making a complete set cost $1966, about the same as the RS's. I know of two yellow track only ITR's which are very fast at Mosport using the Tein RS, and two guys using the Advance Design models in some Toyota Supras driven on street and track, and they say they are fantastic. One of them finds that the Advance Design coil-overs make more noise than he would like, but he has decided to live with it since he likes the coil-overs so much.
Old Apr 23, 2003 | 10:23 PM
97 TYPE-R 312
Guest
Posts: n/a
My vote is on the TEIN's. Tim, let me know if you're looking to do some. I will be doing a set of RE's this summer, along with some other local R's doing, RA's to FLEX units.
-Victor
Old Apr 27, 2003 | 04:44 AM
descartesfool
After speaking with both Greg at Teinusa and Jay Morris at Ground Control, I decided that the person who knows the most about shocks should get my money, so I ordered a set of Jay's Advance Design aluminum coil-overs, $399 ea. plus $55 ea. for springs. Jay said I did not need new upper spring mounts since the ITR stock one's are excellent. I compared the dyno curves of the Tein RS ( these have the external attached reservoir with adjustable bump) with a dyno curve of a set of Advance Design coil-overs, and found both to be quite similar in terms of actual rate and range of adjustability. It was hard however to compare the slow speed bump and rebound due to lack of detail in the Tein dyno curves. Slow speed bump and rebound are what affects the car when you turn into or out of a corner, or when you brake or accelerate. High speed damping is related to shock's response to sharp bumps. The Advance Design coil-overs have good adjustability in the low speed bump part by choice, in order to best adjust the car for handling. This is why I wanted separate adjusters for bump and rebound.
Another feature which helped me choose the Advance Design over the Tein's is the fact that I get the springs I want and valving to match for the original price. In my case, Jay recommended 450 lb springs front and 550 lb springs rear, and by adding a pair of 650 lb springs for an extra $110, I can run 550 front and 650 rear. If I had chosen Tein's, you first pay for the stock set (which comes with higher rate front than rear springs which I did not want), and then you pay to revalve the shocks, which for the spring rates I wanted, would have required an extra $160 ea. or $640 extra, plus any springs. I had also checked out the Tein N1's which I assume are similar to the Mugen N1's, but the springs and damping are twice as hard as the Tein RS, and so not suitable for a car being driven to the track. If after learning how to drive the car I decided I want to use even higher springs (going towards the 800 lb front, 1200 lb rear used by Realtime Racing's ITRs), then Advance Design can rebuild the coil-overs for only $50 ea. A good deal I think.
With regards to shock info, Jay said the best book he had found describing shocks was the one by Paul Haney called Inside Racing Technology (out of print but look on Amazon.com for used copy). Paul Haney on his web site www.insideracingtechnology.com also recommended in his book reviews section the Ohlins TT44 damper manual. He says "the most practical information yet presented about racing shock absorbers". Paul Haney also has a new book, "THE RACING & HIGH-PERFORMANCE TIRE", which I just ordered. Ohlins is a very high performance shock manufacturer (Jay told me he thinks they have 40 engineers working on their products), and the TT44 is a shock used by CART teams, but if you are technically minded, it is worth a look. Call Ohlinsusa, $26 for the manual on CD. It is amazing how complicated shocks can be. Some people spend so much time worrying about headers, which are really very simple in comparison, and cannot be adjusted to your car. A friend of mine reduced his lap time by 4.5 seconds at Mosport by installing a set of Tein RE's on his ITR, and he only improved 1.5 seconds with a ton of engine compartment mods (including headers), which also gave him overheating and other problems. Number of problems with coil-overs was zero.
Aj was lucky to get some of the Ohlins products, but I could not afford them. Motons would have been nice too!
Old Apr 27, 2003 | 05:26 AM
George Knighton
Guest
Posts: n/a
Originally Posted by Trey
I am running Zeal Function B6's. Just Sold my TEIN HA's to make the change.
Both were good, the Zeals are that much better.
What spring rates are you running, if you don't mind?
Old Apr 27, 2003 | 05:34 AM
George Knighton
Guest
Posts: n/a
I'm not sure if this is an indictment or a sign of their excellence ( ), but using shocks like this will bump you up a class in Honda Challenge.
You'd be running against NSX's and killer hybrids.
