steering wheel question
Old Feb 19, 2003 | 10:13 AM
phoenixR's Avatar
phoenixR
when changing to an aftermarket steering wheel such as the sparco color 2. how would you go about gettin rid of the factory air bag in the wheel. disconnect it or remove the fuse? and once that is done would that disable the passenger side airbag? finally does anyone know what sparco hub kit will work on the integra? i believe its the one for 88-93 civic and crx, but i just wanna double check. thanx for the help.
chris
01 itr #636
Old Feb 19, 2003 | 11:24 AM
Erik B's Avatar
Erik B
I dont know how the hub but if you pull the fuse it will disable your passanger side air bag. All you have to do is un plug it. Your SRS light will be on. If that bothers you just take the bulb out from the cluster...hope that kinda helps.
