buttons?
Old Dec 3, 2002 | 04:08 PM
hopofthese's Avatar
hopofthese
whats up guys. i am debating whether or not to remove my rear window wiper of my itr, and i dont know whether or not to go for it? i also want to know is there any suggestions about what should i do about the free button? i would like to run a fule cut off there but i have no clue in doing so?
Old Dec 3, 2002 | 05:10 PM
paul98itr's Avatar
paul98itr
No clue either, but that would be phat!
Old Dec 3, 2002 | 09:57 PM
Aj's Avatar
Aj
You could rig it so your fuel pump will only turn on if your rear winshield wiper is on, that's not real hard, this way it would be much harder to steal.
Easiest way I'd say to do that would be to use a relay at the fuel pump, and have the switched power tapped into the wire running to the rear winshield wiper motor. I'd say no more then like 10 bucks in parts and maybe at most 40 mins to do it.
If you need some more help, let me know, I'd be happy to any way I can.
Later,
Aj
Old Dec 3, 2002 | 10:39 PM
bbasso
Guest
Posts: n/a
I took my rear wiper off a long time ago and have no regrets, in fact going thru the car wash has been easier (nothing for the rags to get stuck on).
As for the fuel thing...
I'm at a loss.
but a momentary switch for the ignition might be better.
Old Dec 4, 2002 | 09:30 AM
Aj's Avatar
Aj
You could do a momentary for the rear winshield washers, just as I said before, but this time you'd need to hook up a relay to your starter, the only problem with doing that is that you'd need two hands to start your car, both on the same side of the steering wheel, and I think that would be rather awkward.
Later,
Aj
Old Dec 4, 2002 | 11:37 AM
hopofthese's Avatar
hopofthese
thanks fellas! but i think i might want to do the fuel cut-off, but the thing is i have absolutely no clue on how to do this, what to buy, or even how to start? :?:
can anybody help out or atleast give me a clue?
