Comptech Sport Springs
Old 11-13-2002, 01:30 PM
98ITR785
98ITR785's Avatar
Hello,
I was interested in putting a coilover suspension on my car, but before I went to order I luckily checked the ground clearance when pulling into my garage. If I lower my car more than an inch, the center of my car will scrape the ground, and even at an inch I may scrape if I don't take just the right path as I pull in. I can no longer justify the expense of coilovers and cornerweighting my car if I'm only going to drop it about 3/4".
So...
I am now thinking about using the Comptech Sport Springs on my otherwise stock suspension. These lower the car an additional 1/2 - 3/4". My car has 67,000 relatively pothole free miles, so one concern I have is if my shocks will blow out significantly sooner. My other concern is if this is likely to improve the cars handling any, or just make it look slightly cooler 8) . I am looking for both.
Thanks,
Tony Alvarez
98 ITR
Old 11-28-2002, 04:43 PM
dub27
dub27's Avatar
Hey Tony,
don't the Comptech springs lower the car approx. 1.25"?
Old 11-28-2002, 05:18 PM
98ITR785
98ITR785's Avatar
They lower the base Integra and GSR 1.25", but the Type R already sits about a half inch lower than those models.
Tony
Old 11-28-2002, 10:43 PM
Aj
Aj's Avatar
It really won;t help your handling at all, if anything it may be a detriment. When you put springs on stock struts, the struts won't perform as well, due to the fact that you changed the geometry slightly, not to mention the valving on the stock strut was meant for a longer spring.
for 1/2 - 3/4 of an inch, I wouldn't even waste the money. I'm not even sure you'd notice a visual difference with that shallow of a drop.
Sucks about your drive way.........try moving.....jk
Later, good luck,
Aj
Old 11-29-2002, 06:50 AM
98ITR785
98ITR785's Avatar
AJ,
Last night I happened to be parked nose to nose with a base model Integra, which from the factory sits .6" lower than my Type R. As you suspected, I couldn't really see any difference.
Thanks,
Tony
Old 11-30-2002, 05:23 PM
paul98itr
paul98itr's Avatar
Why does the base model sit lower? Your r has a 10mm lower from the factory! :?
Old 12-01-2002, 01:08 AM
98ITR785
98ITR785's Avatar
Oops, I meant to say the opposite, that the R sits lower by .6" (15mm).
Tony
Old 12-01-2002, 02:52 AM
joe s
joe s's Avatar
I agree with aj; I'm sure the handling from the factory set-up is fairly optimal, and the slight lowering of your proposed change, if noticable at all, won't make it look any cooler than it already is. All it will do is SCRAPE more!
