What kind of cams for an S/C setup??
Old Feb 9, 2004 | 08:31 PM
jockJDM's Avatar
jockJDM
Banned
Default What kind of cams for an S/C setup??
I got a 98 GSR with AEM short-ram intake, greddy evo2 cat-back, and DC 4-1 ceramic header. I plan on super-charging down the line, but I want to get some new cam shafts first. I was thinking of some Toda Spec A cams to compliment the supercharger. The car has less than 50K miles on it and has been taken well care of. Any other things I should know before I move on with what I described?
Old Feb 9, 2004 | 08:41 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
For the cost of a set of Toda cams and a supercharger, you could purchase a turbo kit which will produce superior results.
Old Feb 10, 2004 | 05:02 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
You would be fine with your current cams and some adjustable cam gears.
Mike is right though. The money spent on a SC and Toda Spec A cams could be spent building and tuning a turbo kit to make more power.
Old Feb 10, 2004 | 02:17 PM
jockJDM's Avatar
jockJDM
Banned
ok so it seems like turbo may be cheaper than getting what i mentioned earlier. but i have decided not to go with a turbo set up since i already got my header and i do not feel like backtracking the stuff i've already done. maybe the toda cams are a bit pricey so an alternative option i had in mind was the skunk stage 1s. keep in mind im getting cams first and any other parts i need to make them run good before i move on to forced induction. on another note, my whp goals are around the 220 range daily driver with some punch so a monster turbo set up is more power than what im looking for.
thanks
Old Feb 10, 2004 | 02:37 PM
Snoopy's Avatar
Snoopy
been there done that
i'd stick with the stock cams as mentioned earlier if you'll be throwing on a sc. the skunk stage 1's you mentioned are more of a NA cam. if you must get some cams, look into the crower turbo/sc grinds.
Old Feb 10, 2004 | 05:21 PM
LT's Avatar
LT
The deer had to die!
get cams that have a longer duration, and slightly higher lift than stock.
Old Feb 10, 2004 | 06:29 PM
Dave-ROR's Avatar
Dave-ROR
RAD owns.
So you can waste boosted intake charges? Uhmmm.. why?
Old Feb 10, 2004 | 10:20 PM
qtiger's Avatar
qtiger
Relatively short duration and as much lift as you can get. Turbo cams would be ideal, and if there's still too much overlap then just advance intake and retard exhaust till its nice n purdy.
slickgsrdrver
3
Jul 1, 2003 10:01 PM
crxb16er
Engine Swaps, Tech & Tuning
4
Jun 2, 2003 01:39 PM
dnt94civic
92+ Civic/EL & Del Sol
18
Nov 13, 2002 10:10 AM
2fastcivic
7
Sep 17, 2002 12:55 PM
