Best Spark plugs?
Old Feb 7, 2004 | 11:28 AM
RboYi's Avatar
RboYi
Default Best Spark plugs?
what would be the best spark plugs? how much would it conventially add to a 80,000 GSR? thanks
Old Feb 7, 2004 | 11:42 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Umm... basically, the only spark plugs you should buy for your car are NGKs or Densos. In fact, don't buy into any of the hype with an aftermarket ignition. If Erik's Racing 9 second all motor civic (with a B18C1) uses stock ignition, then I'm sure it's good enough for my use.
On my GS-R, I use OE copper NGK plugs from an LS, regapped to GS-R spec. Since copper's one of the best conductors, it produces one of the best sparks. The problem with copper is that the plugs last 10-15K miles AT MOST, so be prepared to replace them at least once a year... but you should be checking your spark plugs every couple months to monitor your engine's condition anyways
I remember hearing that some Miata owners were claiming a whp boost of 3hp by using copper over platinum plugs. Who knows? I've never dyno'd with just a plug change, but you will certainly feel an improvement if you're in need of new plugs.
Old Feb 7, 2004 | 02:06 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The stock NGK platinums are the way to go. They last a long ass time and there's not a hugely noticeable difference with copper. You can run the copper ones and "get a better spark" but it's really no big deal and they need to be replaced sooner. If you want to spend less money and don't care about having to change them out sooner than the platinums then by all means go ahead and get the copper.
Chrgsr96
6
Jul 21, 2003 08:30 PM
Civic_GSR
Engine Swaps, Tech & Tuning
6
Jun 25, 2003 07:27 AM
CivOnDubs
7
Dec 29, 2002 08:04 PM
madlow
4
Sep 1, 2002 06:33 AM
showgunz
Aug 26, 2002 07:32 AM
