Compression Question
Old Jul 30, 2002 | 04:55 PM
onesikgsr's Avatar
onesikgsr
Default Compression Question
What would be the highest compression ratio u can run on a 96 GS-R, but still keeping it streetable at 91 octane gas? And what pistons would u recommend to do the job?
Thanks,
Matt
Old Jul 30, 2002 | 04:58 PM
Kevin's Avatar
Kevin
Banned
hMM...id like to see the NA guys answer this too...
n archive it
Old Jul 30, 2002 | 04:59 PM
WeaselGSR's Avatar
WeaselGSR
I don't think I'd go much over the stock compression with 91 octane gas
check out the endyn pistons
www.theoldone.com
Old Jul 30, 2002 | 05:01 PM
4doorLS5spd's Avatar
4doorLS5spd
You could very safely upgrade to stock Type R pistons, etc. That would bump up the compression a bit.
Old Jul 30, 2002 | 05:04 PM
WeaselGSR's Avatar
WeaselGSR
That's a 10.5:1, that should probably be fine, but up it to premium if you get detonation
Old Jul 30, 2002 | 05:07 PM
onesikgsr's Avatar
onesikgsr
What do u think about the JDM ITR pistons with a compression ratio of 11.1? Is that too high or would that probably be the limit for a 91 octane street Naturally Asperated GS-R
Old Jul 30, 2002 | 05:11 PM
WeaselGSR's Avatar
WeaselGSR
I run 93 right now anyway, I definitely would running 11.0:1
Your engine does have knock sensors that will retard the timing if you have detonation, you might want to talk to someone with specific experience, general rule of thumb is 11:1 is the top end of what you can run on pump gas
But I'm from the muscle car camp, I'm new to imports
Old Jul 30, 2002 | 05:25 PM
evo119's Avatar
evo119
GO GIANTS!
I've seen as high as 12.0:1 on 91 octane gas, however that's on a properly tuned engine. IMO I wouldn't go that high...JDM ITR pistons are good enough. Or JE Pistions with the same CR.
Old Jul 30, 2002 | 10:43 PM
Guest
Guest
Posts: n/a
dont some of the new toyota's come with 11:0:1 CR? they run on 91..why couldnt he? goodluck
Old Jul 31, 2002 | 12:09 AM
dubcac's Avatar
dubcac
I
With proper tuning you can go to around 12:1, maybe slightly over on 91 octane.
