Headlights
Old Jan 31, 2004 | 08:12 AM
stasi's Avatar
stasi
Default Headlights
I'm looking for some specific info on the bulbs in my headlights.
I obviously don't have the owner's manual, just a Helm's.
I have a 92 LS, 100% stock and was looking to replace the original bulbs
with something that would hopefully increase overall vision or light
projection as I drive at night. What would be safe to use? I was in Pepboys
the other night and was looking at bulbs with numbers like 9005, 9006 etc.
Any help is greatly appreciated. I'm a newbie. :a:
Old Jan 31, 2004 | 10:25 AM
acuragal03's Avatar
acuragal03
PIAA is definitely the way to go. you can order them online. if you want better piaas, order them straight from japan. piaa from here are $80, jdm piaas are $110. it's definitely worth the extra money. now, these bulbs aren't going to last quite as long as stock bulbs because the watts are higher, but if want a good looking brighter bulb, you have no choice. by the way, 9005 are the high beams, 9006 are low beams. good luck.
Old Jan 31, 2004 | 10:32 AM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
i would get the sylvania silverstars .. its 20 bucks a bulb... there is a way to do the "9005 conversion" which you can modify your high beam bulbs to fit in your low beam sockets.. fairly easy to do..
http://www.team-integra.net/sections...005+conversion
check out the link
Old Jan 31, 2004 | 10:36 AM
stasi's Avatar
stasi
Should I be looking for any particular wattage?
Old Jan 31, 2004 | 10:38 AM
stasi's Avatar
stasi
Excellent. I'll be sure to read up on the conversion after I leave here (work). Thanks for the help. :cheers:
Old Jan 31, 2004 | 10:55 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Silverstar >>> PIAA
In my opinion
Old Jan 31, 2004 | 01:32 PM
RB's Avatar
RB
snitches get stitches
Or you can get jdm one pieces and use Raybrig H4H's...
Old Jan 31, 2004 | 02:56 PM
Meguel24's Avatar
Meguel24
Platinum Plus Member
As a matter of fact I just did a 9005 conversion this AM. I have piaa 9005 xtreme white and one bulb went bad. I sent them back last week and got new ones yesterday. Did the 9005 conversion again and I'm a happy man once more.
Old Jan 31, 2004 | 05:13 PM
iNteGraz92's Avatar
iNteGraz92
forever lurking
G2's use crappy 9004 bulbs
Old Feb 1, 2004 | 06:18 AM
stasi's Avatar
stasi
Will the Silverstar's really be a big difference in comparison to my stock bulbs?
