Side Moldings Question
Old Dec 22, 2003 | 11:04 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
Default Side Moldings Question
If I remove my side moldings would there be any holes left on the door?
Old Dec 22, 2003 | 11:39 PM
v-teg01's Avatar
v-teg01
Candy
Do you mean your side skirts? and what kind of car do you have? I have a 2001 GSR and i had my side skirts painted, they took them off and it looked like i had a rail with a bunch of holes in it. I dont know if that helps you but thats my knowledge
Old Dec 22, 2003 | 11:54 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
mine is a 94-97 LS, probably the same. If the GS-R and the Type-R are the same chassis, how come the type-r has no rail looking holes?
Old Dec 23, 2003 | 02:03 PM
Snoopy's Avatar
Snoopy
been there done that
yes there will be holes
Old Dec 23, 2003 | 02:06 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Same chassis (With some slight modifications), but a slightly different sheet metal body...
Old Dec 23, 2003 | 02:17 PM
JGordon's Avatar
JGordon
If your side moldings are black, you might consider getting them painted. I had my stock side skirts and side moldings painted body color for $225, still looks good 1 year later.
Old Dec 23, 2003 | 02:40 PM
forum95's Avatar
forum95
I'm Cooler than You
Holes are teh nastyness
Old Dec 23, 2003 | 06:53 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
You will have holes when you remove the bump strips. The best way is to get them welded to avoid them "dimpling" over time with bondo or some other element.
Old Dec 23, 2003 | 09:52 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
is there any adhesive on the strips? Because i believe i can paint them myself if I can remove them and put them back on without a problem. Since they are rubber, would I need to use primer?
Old Dec 26, 2003 | 07:57 PM
MikeR's Avatar
MikeR
i got side swapped in my old parking lot and it gouged out my rr 1/4 panel trim piece. i scuffed it up with scotch brite, cleaned with thinner, primed and painted and all good, you can get a way with just scuffing, cleaning and painting just fine, just make sure to clean/strip all wax etc... off before you spray
