E-brake light stays on....
Hello all,
My E-brake light stays on after the brake handle is lowered. It usually goes out after driving a while. The e-brake does disengage, the light just stays on.
Any ideas?
Thanks,
Scott
2000 Integra GS-R
Any ideas?
Thanks,
Scott
2000 Integra GS-R
alteast you dont have your damn check engine light and seatbelt light on...well the seatbelt light is fixable (i just have to wear it) and i think my check engine light is on from an overdue oil change:dunno:
about the e brake light, my friend had that problem but im not sure how he fixed it, i can ask thought:dunno:
The Brake light is due to either low brake fluid, or you need to change the pads.
As far as the maintenance light goes. Go under the dash, on the right hand side, just above where your right knee would be, there is a small box with a beige button. Just hold down that button while turning the ignition on, and this will turn the light off.
My fluid wasn't low, and nothing was wrong. I simply took the dipstick that goes into the brake resevoir and turned it upside down a few times so oil ran all over it. Hasn't ben on since
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
i think mine is fried cause after i got my amp installed it stopped working...i checked the sensor on the ebrake handle and it didn't fix it so i am thinking the wire is fried but i don't know what wire and where to run it from
