Drifting and Grinding
Old Nov 2, 2003 | 06:45 PM
97teg's Avatar
97teg
Maybe try checking tire pressure. Ive noticed in my car sometimes when it pulls it cause the tire pressures are off form each other. If it doesn't do anything you didnt' waste anything.
Old Nov 2, 2003 | 08:02 PM
Microbrewa's Avatar
Microbrewa
how do i go about fixing my alignement?
Old Nov 2, 2003 | 08:05 PM
Shore 96 Teg's Avatar
Shore 96 Teg
I miss my 93 VTEC Lude :(
go to any place that does work on suspensions. are you lowered? if so prepare to pay an arm and a leg for it. alignments on stock suspensions arent cheap either.
Old Nov 2, 2003 | 09:07 PM
Unklejman's Avatar
Unklejman
Skidmarks in the driveway
First go to a flat parking lot and see how it goes. Remember, roads usually ascend to the center so that water will run off, which will make your car want to drift ever so slightly right even if you are in alignment.
Old Nov 2, 2003 | 10:17 PM
AcuraSpeed's Avatar
AcuraSpeed
it might not be the alignment. If you have high traction tires (say Z rated) then that can cause your car to follow the general curve of the road a little more than seams natural...same thing happens with my and my Z's.
Old Nov 3, 2003 | 12:07 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally posted by integsracer
thanks for the info dc4. by the way, is your sig picture edited? your lights look REALLY bright? i like it =) how did you get them so bright?
Well....
Part of it is the angle of the shot. It's actually rather low. About knee height.
Part of it is the fact I had just replaced both bulbs, and washed/waxed prior to shooting that pic.
And the rest is a bit of subtle color level tweaking in GraphicConverter.
A bit more red and blue contrast does amazing things..h:
Thanks for noticing though.
