post your compression test results here!!!
Old Oct 31, 2003 | 12:07 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
Default post your compression test results here!!!
i'd like to know some of your results and from what year, model, milage, and pistons cause i don't think mine came out correctly..
i'll start,
year: 1996
model: gsr with USDM ITR pistons
milage: not even 2,000
results: about 180-190 across :eh: i thought it would be higher cause my compression is around 10.9: 1
Old Oct 31, 2003 | 12:17 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Shouldn't you be sitting at 210+?
At least they were all at the same rate... that's good!
Old Oct 31, 2003 | 12:19 PM
KKTPP's Avatar
KKTPP
i got a 1995 teg ls
196,xxx KM on my car
the motor is in sweet condition for how much i abuse it
my car is stock
cylinder 1 = 174, 2 = 167, 3 = 166, 4 = 172
i dont have my timing retarted or compression changed... thats just the results i got when i did it..
im gettin my engine bored out to like 1.9L.. gettin bigger pistons and all that junk.. so for those ppl that are gonna tell me to get new piston rings.... i'll get em later :P
Old Oct 31, 2003 | 12:49 PM
SUPER LAUBO
KiMBO's Hubby
that's exactly what i thought.. :dunno:
i wonder if my compression tester had anything to do with it because i did it by myself with the tester laying on the block.
Old Oct 31, 2003 | 12:55 PM
Epoch's Avatar
Epoch
That shouldn't be a problem though... meybe you can borrow a friends?
If two testers give you identical numbers, it might be a good idea to check your valves maybe?
Oh... and I'll do a compression test on my stock-internals GS-R tomorrow... I'm ramping up for halloween right now :-D
Old Oct 31, 2003 | 01:28 PM
SUPER LAUBO
KiMBO's Hubby
oh, i just called Comptech and asked them about the lack of compression. they said your pressure will vary depending on the temperature of the block.
i remember doing the compression check from a cold start after leaving my car overnight. i'll try to do it again with a warm car.. :thumbup:
