Brake Light in the Gauge Cluster
Old Oct 22, 2003 | 08:18 AM
94civicEX's Avatar
94civicEX
I got worms.
Default Brake Light in the Gauge Cluster
My Brake light wouldn't turn off this morning after releasing the e-brake. Hopfully it was just cause it was chilly last night, but what are my options?
Thanks :happysad:
99 Integra GSR
06 TSX
duck squad member #00003
Old Oct 22, 2003 | 08:24 AM
94civicEX's Avatar
94civicEX
I got worms.
Oh, searching ownz me:
https://www.honda-acura.net/forums/s...threadid=93204
Any other suggestions?
99 Integra GSR
06 TSX
Old Oct 22, 2003 | 08:28 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
youre low on fluid chuckles.
check your master, make sure its full.
Old Oct 22, 2003 | 08:30 AM
94civicEX's Avatar
94civicEX
I got worms.
I will when I get out of these bloody classes. I'm sure that it is full, if it is?
99 Integra GSR
06 TSX
Old Oct 22, 2003 | 08:35 AM
Fujiwara Takumi
It's my first day.
bleed your brakes
do you have good pedal?
could just be the little button on the underside of the emergency brake. if you take out the center console you will see a wire with a little push button. you have to make sure that its OPEN when the brake is down, touching it.
Old Oct 22, 2003 | 08:36 AM
94civicEX's Avatar
94civicEX
I got worms.
Everything should be kosher. I think it's related to the temperature. I have Goodridge SS lines as well.
99 Integra GSR
06 TSX
Old Oct 22, 2003 | 08:39 AM
Fujiwara Takumi
It's my first day.
the button has a wire that comes off really easy. maybe look at that.
Old Oct 22, 2003 | 08:42 AM
94civicEX's Avatar
94civicEX
I got worms.
I'll check it out if it doesn't go off. But in that case the brakes would not have released? Or is that just the sensor part? Cause the brakes released.
99 Integra GSR
06 TSX
Old Oct 22, 2003 | 08:54 AM
Fujiwara Takumi
It's my first day.
the "sensor" is just basically a plastic push button switch. when the ebrake handle is down it pushes on the switch and the car switches your brake light off.
Old Oct 22, 2003 | 11:15 AM
94civicEX's Avatar
94civicEX
I got worms.
Oddly enough when I got back in my car it turned off. We will see if it repeats itself.
Thanks Blake.
99 Integra GSR
06 TSX
