ABS light comes on after lowering car
My brother, me, and our friend just got lowering his Integra with new shocks and springs, everything is fine with the car, but the ABS light came on.
Drove the car around, no strange squeaks or rattles, and I took a couple of hard stops and the tires locked up so the ABS is definitely not working.
We know for sure that nothing in the front was damaged because all we had to do was push around the brake lines, but I think in the back we may have stretched some wires when we were removing/installing the struts.
I'm a Civic guy, usually post in the Civic forums, you guys help a brother out.
TIA.
TIA.
Sounds like you damaged one or both of the rear ABS sensors. Your local Acura dealer can diagnose this for you...if they are cool like mine they will do it for free and let you know the cost to replace it...make sure to get any part numbers from them so you can look online for cheaper.
I did the same damn thing on my GS-R. Damaged the right rear wheel speed sensor. It cost me $250 to fix. You can do the diagnostic test yourself with a paper clip. I don't have the link to the codes though.
Ok, we used a ghetto Haynes manual and jumped the service connector, gave us a code "15". Translates to wiring shorted to body or shorted to power. Going to jack up the back and take another look at the wiring, hope we can fix this stuff on our own.
