Is adjusint valves hard?
you can get the tool from snap on. it is a screw driver and socket all in one.
when adjusting valves you use the flat head screw driver to adjust the valves. The place you put the flat head screw driver to is in the middle of a bolt. The screw driver goes in the middle, and the socket goes around the outside. You have to hold the screw driver tight to keep the bolt from adjust even more when you are tightening up the bolt.
it's fairly easy on a gsr
just make sure you get angeled or bent feeler gauges, do not bend straight ones and use them.
www.c-speedracing.com for more information on valve adjusting including step by step.
Originally posted by Bumnah
[B]just make sure you get angeled or bent feeler gauges, do not bend straight ones and use them./B]
Originally posted by juiceweazel
so how the heck do they manage to get it adjusted right when u bring it into the shop? they're not going to have it sit overnight for a $100 job. how long does it take? about an hour?
Originally posted by slickboy
valve cover off and put a big fun over the engine bay and let it run for about 2 hours before doing the adjustment.
Originally posted by 1funride
Exactly what Honda does when they adjust your valves...When I had mine done for the 60k service my car was in and out fairly quick..I asked them how come it was so fast, there reply was what was quoted above..
If your car was out fast, that most likely means they just popped off your valve cover and deemed that everything was within specs. Which is a little
because those readings are not accurate when the car is warm.
Originally posted by qtiger
There's a little screw that you move up and down to adjust spacing of your valves, then you hold that setting steady with a nut.
