Synthetic worth it?
Old Sep 2, 2003 | 11:09 PM
Dimi's Avatar
Dimi
Default Synthetic worth it?
Is synthetic fluids worth it on Hondas? Always used Castrol GTX regular oil and regular Fram filters on my other Hondas. But $30 in oil and filter seems kinda high for one oil change but is it worth it in the long run? I just purchased this Civic with 115k and was wondering if it'll be ok to run it? Or worth it? Anyone run Synthetic and do you notice a better running vehicle?
Old Sep 2, 2003 | 11:11 PM
fook's Avatar
fook
Boosted D Series
number of times the oil topic has been covered is now
27,105,867,231
drive thru please...and please note the search button.
Old Sep 2, 2003 | 11:12 PM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
They help reduce engine wear, so if this is what you want than it is worth it. I plan on keeping my car for a long time so I only use synthetic.
Old Sep 2, 2003 | 11:32 PM
Dimi's Avatar
Dimi
27,105,867,231
Aiight bro relax. I didn't know this site was up that long so I didn't know it's been covered that many times, I bet it's happened to you so be easy. Simple question, worth it or not. Thanks...
Thanks jinx, I'll see into investing in some...
Old Sep 3, 2003 | 12:29 AM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
see in investing into some new oil filters too,..fram sucks ass,...they are notorious for leaving the O ring behind which will prevent the new filter from going on properly,..which in turns,..leaks oil,...im a mobil 1 tri-synthetic oil user,..and i use mobil 1 filters
Old Sep 3, 2003 | 02:07 AM
Dimi's Avatar
Dimi
Indeed I know about the oil ring...but I usually check thoroughly on it when I change it. With the Mobil1 synthetic and Mobil1 filter...how many miles do you get on it or how many miles do you change the oil and filter?
Old Sep 3, 2003 | 05:53 AM
Wharbone's Avatar
Wharbone
Widebody, what kind of filter do you use?
Dimi, I use Mobil1 and like it. Mobil1 and changing it myselft costs about the same as paying someone else to put cheap oil in it. I think it is worth it.
Old Sep 3, 2003 | 11:04 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I personally think if you live in a hot or cold climate and value your engine synthetics are a better investment. Plus you can wait a little longer between oil changes (not filter changes) with synthetic.
PLus the viscosity stays more consistent with synthetic oils compared to their conventional oil counterparts. So your engine stays protected better from metal to metal contact.
Autocross Help Page
Old Sep 3, 2003 | 12:20 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
yes, it is well worth it...i read an article about it some time ago and if you plan on maintaining your car. BUY IT..but just don't break your car in with it... :thumbup:
Old Sep 3, 2003 | 12:30 PM
Wharbone's Avatar
Wharbone
Ok, stupid question here. If I just change my filter and not my oil, will oil go all over, or will it be just like it normally is when I change oil where a little oil comes out. Sorry for asking, but I've always drained my oil before I took the filter off.
