Check Engine Light 45
Old Jul 10, 2002 | 11:35 PM
Unjockable's Avatar
Unjockable
Default Check Engine Light 45
System Too Lean or Too Rich
How do I fix this problem?
Old Jul 11, 2002 | 07:46 AM
98EX's Avatar
98EX
Insane Wierdo
VAFC is the easiest
Old Jul 11, 2002 | 10:13 AM
Unjockable's Avatar
Unjockable
Originally posted by 98EX
VAFC is the easiest
what is a VAFC?
Old Jul 11, 2002 | 10:46 AM
qtiger's Avatar
qtiger
Do you have an aftermarket fuel pressure regulator, aftermarket injectors, fuel rail, fuel pump, etc, etc?
Old Jul 11, 2002 | 11:05 AM
98EX's Avatar
98EX
Insane Wierdo
Originally posted by Unjockable
what is a VAFC?
VTEC-Air Fuel Controller(I am assuming you have a DOHC or SOHC VTEC) if not, then just your basic AFC will work.
Old Jul 11, 2002 | 12:18 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Did you do any mods directly prior to getting this code?
Old Jul 11, 2002 | 12:37 PM
Unjockable's Avatar
Unjockable
I have a B16A2 with just intake and straight pipe. That's it. No other mods. How much is that air fuel controller? What does it basically do anyways?
Old Jul 11, 2002 | 01:17 PM
98EX's Avatar
98EX
Insane Wierdo
You're running a straight pipe? This could be related to why you are runing rich/lean. Your ECU could be reading too much on emmissions and leaning your fuel mixture out to try and correct it.
Old Jul 11, 2002 | 01:25 PM
Unjockable's Avatar
Unjockable
I don't think it's because of the straight pipe because I had the code even before the straight pipe. can i fix it by buying the VAFC? Also, how much and what does it bascially do?
Old Jul 11, 2002 | 01:46 PM
98EX's Avatar
98EX
Insane Wierdo
It might be a possability, but you need to find out why you are too rich/lean first cause it may be just a simple thing you need to do instead of haveing to go buy a $300-$400 piece of electronics.
