Need Assistance
Old 07-16-2003, 09:28 AM
96GreenCivic
96GreenCivic's Avatar
Default Need Assistance
Ok, here is the story.
As most of you have seen, I put on 16" rims and tires 205/45.
When the shop installed it, I called them b/c the steering wheel was vibrating whenever I went over 60mph. It turned out that they accidently stripped one of the studs. So they I ran with 3 out of 4 lugs for 2 weeks while they ordered a new stud. While running on 3 lugs, the vibration went away and the ride was great. So we were thinking that the 4th bad lug didn't set the wheel right. 2 weeks later, the stud is replaced and I have all 4 lugs again, (pass front btw). Guess what, the vibration is back sporadically. Kind of annoying! I was thinking if I took off the rim and hand set and criss cross pattern tightening may help. If it doesn't ...... any suggestions?????
any help or ideas are appreciated.
File Type: jpg
Old 07-16-2003, 09:34 AM
Cashis EG8
Registered Rota Dealer
Cashis EG8's Avatar
I don't know what wheels those are, but it sounds like you need hubcentric rings.
Old 07-16-2003, 09:42 AM
pinoyboy
im asian
pinoyboy's Avatar
hey nice rims
Old 07-16-2003, 10:08 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
you should always criss-cross tighten lug nuts. :eh:
Old 07-16-2003, 10:32 AM
96GreenCivic
well, the shop did install some sort of plastic ring before they put on the rims. Is that a hubcentric ring?
Old 07-16-2003, 10:48 AM
Dub2045
Dub2045's Avatar
Have your wheels been balanced?
Old 07-16-2003, 11:00 AM
pinoydon2003
pinoydon2003's Avatar
same thing happened when i got my rims/tires.. they weren't balanced/mounted properly.. if there's still vibration, get ur alignment done
Old 07-16-2003, 12:03 PM
purplx
purplx's Avatar
balance and/or alignment.
Old 07-16-2003, 01:03 PM
96GreenCivic
i had the shop check the balance and it was within specs. So I guess I'll try remounting them and if that doesn't work I'll get the alignment. PS what is the avg rate for a front end alignment?
Old 07-16-2003, 07:51 PM
Grifter
Grifter's Avatar
