DRAG 3 TURBO for gs-r
Old Jul 9, 2002 | 08:08 PM
SiR-G's Avatar
SiR-G
Default DRAG 3 TURBO for gs-r
im thinkin bout geting this turbo for my gs-r...my question is do ya think its a good turbo or not..also is it good to run this turbo on stock internals?..so far all i have is h/i/e and direct port nitrous..i only sprayed 2 bottles worth since i have gotten the nos system...but that wuz just testing..havent been abusin it. so do u think its still safe to run da turbo under my stock internals?..as u can see ima n00b at engine stuff so any help would b great...:dunno:
Old Jul 9, 2002 | 08:32 PM
knight0118's Avatar
knight0118
well the turbo its self is a great turbo the t3t4 hybrid...the setup is top notch as well..make sure u upgrade to the tial wastegate..as far as your engine setup your not going to be using your header or intake..and i would recomend cutting the nos use if u get the turbo....running stock boosts which seems to jump around between 8-10 will be fine on your stock internals...
Old Jul 9, 2002 | 08:39 PM
SiR-G's Avatar
SiR-G
thax for the info...what do you think about the ball bearing upgrade?..and what else do i have to upgrade for the extra power...injectors,etc..
Old Jul 9, 2002 | 08:48 PM
XSrcing's Avatar
XSrcing
the ball bearing upgrade will help reduce lag, so if you have the money go for it. but, if you ever need to rebuild the turbo, it will cost more. what you should do if you buying the turbo kit is sell the intake, header, and nitrous system then invest that money in Hondata, and a turbo timer(i'm not sure if hondata has one). that will make sure you dont run lean, and the turbo timer will help ward off the need for rebuilds.
Old Jul 9, 2002 | 08:54 PM
SiR-G's Avatar
SiR-G
should i drop the compression ratio for the turbo?..and where do they sell the ball bearing upgrade at...i cant find it anywhere
Old Jul 9, 2002 | 09:09 PM
Snoopy's Avatar
Snoopy
been there done that
drop compression if you plan on running over 10 psi of boost. otherwise its not totally needed.
Old Jul 9, 2002 | 10:56 PM
knight0118's Avatar
knight0118
ball bearing also help in reliability of the turbo...when the turbo isnt spooln the oil sits in the turbo no where to go with ball bearing the oil keep movin when turbo stops...helps the life of the turbo a lot!
check out turbonetics for ball bearing turbos...
Old Jul 10, 2002 | 11:53 AM
hks240sx's Avatar
hks240sx
T U R B O is fun =]
and i recommand it =] very very very MUCH! ! ! !
Old Jul 10, 2002 | 01:46 PM
<SIN>'s Avatar
<SIN>
You will love it, so much power, get Drag III kit
Old Jul 12, 2002 | 10:05 AM
98redgsr's Avatar
98redgsr
i just got mine and i have not put it in yet. i will let you know.
