Want to get into Low 14's high 13's all motor D16
Old 07-14-2003, 01:54 PM
New93Civ
New93Civ's Avatar
Default Want to get into Low 14's high 13's all motor D16
I want to keep the D16 and get it moving good. Do they make Strocker kits for the D16Z6. I know I will have to get a lot of head work done and have that planned out. What cam Should I use and what should I do with the Bottom Half. I will spend 5000 grand on the motor i f I have to. I will also give it Some Nitrous to try to push Twelves. I just need some help on the bottom half and the Cam and Intake.
I dont want to go B Series I want to go fast and pull on those B s
Old 07-14-2003, 02:05 PM
flipped cracka
BOOM goes the dynamite!
flipped cracka's Avatar
good luck.
but if you're going to spend 5k on this, why not get a b series. it'd be alot easier to get that fast with a b.
Old 07-14-2003, 02:09 PM
theguy386
I am tehguy... OH YEAH!!
theguy386's Avatar
True true true.
But hey if you happen to run 12s let me know cuz I have the same engine. (not for long). :naughty:
Old 07-14-2003, 02:11 PM
19.3secS2K
my bum is on the swedish!
19.3secS2K's Avatar
Originally posted by flipped cracker
good luck.
Old 07-14-2003, 02:13 PM
New93Civ
New93Civ's Avatar
12's on spray. I need to know what to throw in the bottom to make it solid. this is my first import. My other car is a 1998 Ls1 Camaro.
Old 07-14-2003, 02:14 PM
Snoopy
been there done that
Snoopy's Avatar
it's not impossible. but its probably gonna take more than $5k to do.
Old 07-14-2003, 02:15 PM
New93Civ
New93Civ's Avatar
All I have done is work on is LS1's and Mustangs turbo 4s and 5.0s. My LS1 runs 12.1 s with a 75 shot
Old 07-14-2003, 02:17 PM
19.3secS2K
19.3secS2K's Avatar
:werd:
but at some point, one would have to draw the line.
well, someone with common sense, anyways. Other than "being different," there's no reason to spend $5k+ on a d-series to get 13s out of it N/A.
FI, now thats another story.... And a considerably cheaper one, too
Old 07-14-2003, 02:19 PM
Snoopy
Snoopy's Avatar
and your point to this?
Old 07-14-2003, 02:22 PM
New93Civ
New93Civ's Avatar
Ok what if I just put pistons and rods and spray the shit out of it. I know I will have to Beef the fuel and I have all the suff for the ignition. Pistons and rod are liike a thousand And I could get the motor out and apart myself. I just need someone to put it together. so like may be 1500-2000 to get the bottom half done. Then some light head work and a cam and intake. With lots of spray I think I can go low 13's if it tunnned right. O
