Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   92+ Civic/EL & Del Sol (https://www.honda-acura.net/forums/92-civic-el-and-del-sol-6/)
-   -   Want to get into Low 14's high 13's all motor D16 (https://www.honda-acura.net/forums/92-civic-el-and-del-sol/83414-want-to-get-into-low-14s-high-13s-all-motor-d16.html)
New93Civ Jul 14, 2003 01:54 PM
I want to keep the D16 and get it moving good. Do they make Strocker kits for the D16Z6. I know I will have to get a lot of head work done and have that planned out. What cam Should I use and what should I do with the Bottom Half. I will spend 5000 grand on the motor i f I have to. I will also give it Some Nitrous to try to push Twelves. I just need some help on the bottom half and the Cam and Intake.
I dont want to go B Series I want to go fast and pull on those B s
flipped cracka Jul 14, 2003 02:05 PM
good luck.
but if you're going to spend 5k on this, why not get a b series. it'd be alot easier to get that fast with a b.
theguy386 Jul 14, 2003 02:09 PM
True true true.
But hey if you happen to run 12s let me know cuz I have the same engine. (not for long). :naughty:
19.3secS2K Jul 14, 2003 02:11 PM
Originally posted by flipped cracker
good luck.
New93Civ Jul 14, 2003 02:13 PM
12's on spray. I need to know what to throw in the bottom to make it solid. this is my first import. My other car is a 1998 Ls1 Camaro.
Snoopy Jul 14, 2003 02:14 PM
it's not impossible. but its probably gonna take more than $5k to do.
New93Civ Jul 14, 2003 02:15 PM
All I have done is work on is LS1's and Mustangs turbo 4s and 5.0s. My LS1 runs 12.1 s with a 75 shot
19.3secS2K Jul 14, 2003 02:17 PM
:werd:
but at some point, one would have to draw the line.
well, someone with common sense, anyways. Other than "being different," there's no reason to spend $5k+ on a d-series to get 13s out of it N/A.
FI, now thats another story.... And a considerably cheaper one, too
Snoopy Jul 14, 2003 02:19 PM
and your point to this?
New93Civ Jul 14, 2003 02:22 PM
Ok what if I just put pistons and rods and spray the shit out of it. I know I will have to Beef the fuel and I have all the suff for the ignition. Pistons and rod are liike a thousand And I could get the motor out and apart myself. I just need someone to put it together. so like may be 1500-2000 to get the bottom half done. Then some light head work and a cam and intake. With lots of spray I think I can go low 13's if it tunnned right. O
© 2026 MH Sub I, LLC dba Internet Brands
