Oil drain bolt torque specs + a few more questions.
Old 07-14-2003, 12:00 PM
sv650smike
sv650smike's Avatar
Default Oil drain bolt torque specs + a few more questions.
First post on this site. I have a 2001 silver civic ex 2 door. 44,000 miles on it in a little over the 2 years I've had it. No major problems so far. I've decided to start changing the oil instead of having someone else do it, so what's the oil drain bolt need to be torqued to?
Also I'm having problems with my drivers side window. It goes down fine as long as you hold the button down, but the auto down doesn't work well at all. It'll roll down a few inches then stop. Anyone else having this problem. Is there a service bulletin out for this?
I also want to switch from dyno oil to synthetic. Is there a recommended procedure for that? Just swap them all at once or gradually mix them until I'm at full synthetic? Ex... 1 qt of syn 4 of dyno this time, next time 2 syn 3 dyno until i'm at full synthetic?
I don't plan on modifying the car as I have a bike to play with, but it's been a great car, easy to take care of and very reliable. Here's a pic of my toy and the car.
Old 07-14-2003, 12:03 PM
sv650smike
sv650smike's Avatar
Default .
damn that one turned out big... here's the bike.
Old 07-14-2003, 12:22 PM
flipped cracka
BOOM goes the dynamite!
flipped cracka's Avatar
you can't mix regular and synthetic oil.
and for the drain plug, i just tighten it until it's tight. works for me. :dunno:
Old 07-14-2003, 12:41 PM
CivicRacr
CivicRacr's Avatar
tighten to around 30 ft.lbs and you can just change from regular oil to synthetic
Old 07-14-2003, 02:16 PM
CivicSiRacer
Honorary Moderator Alumni
CivicSiRacer's Avatar
It's 15-20ft/lbs for the bolt.
And don't mix the oil. Just put in synthetic and you will be fine.
Autocross Help Page
