Dumb oil change question
Old Jul 13, 2003 | 12:32 PM
Slacker's Avatar
Slacker
Default Dumb oil change question
How much oil does a b18c take and since I can't jack uphe front of my car... which side would be better to jack up, if any.. so all of the oil drains out.
Old Jul 13, 2003 | 12:43 PM
CivicRacr's Avatar
CivicRacr
i believe its four quarts and jack up the driver side.
Old Jul 13, 2003 | 01:11 PM
SiCivic's Avatar
SiCivic
the newer vtec honda engines usually take about 4.2 liters which converts to roughly 4.4 quarts.
i dont see many vtecs where i work, pennzoil, but im pretty sure that is the right amout... just check at 4 and then add till you are content... its the best way to do it.
Old Jul 13, 2003 | 01:12 PM
Jessica's Avatar
Jessica
ch1x0r
^^i concur
you should get some ramps though, $30 at car place. gets your car higher up.
Old Jul 13, 2003 | 03:27 PM
Ronin's Avatar
Ronin
i use ramps when i change my oil . I agree they work really well and seem to be pretty safe. Just make sure you line them up right and nothing is underneath them(so they don't slide)
ronin
Old Jul 13, 2003 | 05:00 PM
Jessica's Avatar
Jessica
ch1x0r
ronin
um, and make sure someone is with you, your tires aren't wet, and when your friend says stop, stop.
uhh, not like i know from experience....
Old Jul 13, 2003 | 05:28 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Default Re: Dumb oil change question
Why can't you jack up your car?
Autocross Help Page
Old Jul 13, 2003 | 06:15 PM
Jessica's Avatar
Jessica
ch1x0r
Default Re: Re: Dumb oil change question
:werd: i wouldn't anyway, too dangerous. but you should still be able to jack it up
Old Jul 13, 2003 | 06:26 PM
SRT_Andy's Avatar
SRT_Andy
You're right, that IS a dumb question, but at least you got some help.
Old Jul 13, 2003 | 06:49 PM
CivicSiRacer
Default Re: Re: Re: Dumb oil change question
You wouldn't jack up your car cause it's too dangerous? Then how do you work under your car? You must be skinny
Autocross Help Page
