Next mods...
Old Jun 11, 2003 | 01:38 PM
LudeRage's Avatar
LudeRage
Default Next mods...
So I got a 16.1 with intake, clutch, flywheel. I only ran twice and I know I can get a 15.9 with better driving. So my goal is low-mid 15's. The next mod I want is a Greddy MX exhaust ($470).
After that I'm debating on what to get next. A header seems logical but its upwards of $400 for a good stainless steel one, and an intake manifold, I believe, puts out a little more power for just $280 (Skunk2). Also, a decent bored out throttle body (JG edelbrock/ STR), can add 5-7 horsepower, and its $380 I believe for a 70mm one (less for 65 mm, 60mm etc).
So my question is what should I get next after the exhaust to fulfill my mid 15's time goal? And don't just say everything, because I have a budget and am trying to get whatever possible during the summer.
So please just list in order what you think I should do, and if a throttle body, list what size, etc etc. I just want a good idea of what everyone thinks I should do. Thanks.
-Mike
Old Jun 11, 2003 | 02:09 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
I'd go header, then cams/camgears with tuning, but that would be the expensive route
But I think that better headers should be your next investment, then maybe a high-flow cat? a good high-flow cat can be pretty damn cheap...
Though, honestly I don't know the best course for a gen 2 non-VTEC. I've got a GS-R and all I know is to get that exhaust out as fast as possible
Old Jun 11, 2003 | 02:32 PM
MountainGSR's Avatar
MountainGSR
Irisher than Thou
How many headers does your car have? I'd go with a good header and possibly high flow cat to complete the airflow part of the engine.
Adding those two to your current list will give your engine a good air base to work off of. Next it would be good to get some semi-aggressive cams, or an intake mani + throttle body and more aggressive cams.
Short answer: I vote header.
Old Jun 11, 2003 | 03:43 PM
LT's Avatar
LT
The deer had to die!
Intake Manifold will actually raise your 60' times because your engine will be bogging, due to less air velocity into the cylinders. Unless you have a turbo or more aggressive cams, don't invest in an intake manifold or throttle-body. Just work on your launch. Tweak the tire pressure so you can get better traction out of the holeshot.
A header would be my next move along with a hi-flow cat.
Old Jun 11, 2003 | 03:53 PM
Chrgsr96's Avatar
Chrgsr96
Default Re: Next mods...
-Mike
I would not worry about a throttle body for now. Personally I don't think they're going to do a whole lot, and for the price that they cost, its too much to hardly get any power. And if you were to get one, a 70mm is way to big unless you are pushing a lot of power. I'm pretty sure Edelbrock makes a 65mm TB which would be fine I would say. But I wouldn't go with the TB untill later.
Do what some of the others said. Buy a good header, get the Greddy exhaust, and then a straight cat and some good driving you will come pretty close to mid 15's I think. I would also look into getting that Skunk2 IM, it helped my gsr out a lot in the top end.
Old Jun 11, 2003 | 03:56 PM
Chrgsr96's Avatar
Chrgsr96
Huh, the IM helped me out quite a bit. But I'm about to install some Skunk2 cams here, so thats mainly the reason why I got it so it would help out as well.
Old Jun 11, 2003 | 03:58 PM
LT's Avatar
LT
intake manifolds will only help in the higher RPMs, they will reduce your low end power/torque.
Old Jun 11, 2003 | 06:46 PM
LudeRage's Avatar
LudeRage
Hmm, well I'm going for exhaust first most definitely.
I suppose a header next, from what you guys said. I don't see why a better Intake manny wouldn't help my 1/4 mile times. High end power is definitely what I need more of and I can do fine with my 60 ft times with some good driving and my clutch
So does this sound good?
1. Greddy MX exhaust
2. Good header (DC Sports/ Greddy)
3. High Flow Cat
4. Intake Manifold (maybe...in the future..)
I think I can hit a 15.5 with 1, 2 & 3, and with lowering tire pressure to the 20's plus getting my 60 ft down to a solid, low 2.2x.
Anyways, thanks everyone for the posts, they were very useful!
If you have anything else, I'm still listening.
Old Jun 11, 2003 | 08:05 PM
Chrgsr96's Avatar
Chrgsr96
That sounds like a good setup. The IM definetly helped me out in my G3 gsr is all I can say. Yes it was all high end power, but it was worth sacrificing the low end. I took off quite a bit on my ET.
Old Jun 12, 2003 | 05:54 AM
LudeRage's Avatar
LudeRage
Isn't a Type R intake manifold very similar the the Skunk2? If so, will it bolt right up to my B18A engine? If it does, I can probably get it cheaper than the Skunk2...
