smoke gray, engine ring leaking?
Old Jun 7, 2003 | 09:46 AM
keefungliu's Avatar
keefungliu
Default smoke gray, engine ring leaking?
!i just bought a 86 prelude. the guy told me the car smoke gray. it is the engine ring leaking. i need to replace the seal. does anyone know how much gonna cost to fix that? and is really the ring leaking or something else wrong? any comment? thanks
Old Jun 7, 2003 | 11:29 AM
crxb16er's Avatar
crxb16er
yah white smoke is burning oil in the combustion chamber, blueish smoke is gas not being burned or a dead cylinder no spark something like that, if ur blowing white smoke there is a good possibility ur rings are fried, could be other things, but rings are the most common, what u want to do is a compression check, go to autozone and rent their little machine to check the compression or go buy one for like 30 bucks, if the cylinder compression goes up to where it is supposed to be but then the needle falls slowly that means uve got air escaping past the pistons, u can use a heavier weight oil to stop oil consumption and make it harder for the oil to get into the combustion chamber but more than likely ur gonna need a rebuild, but a rebuild isnt that cheap, requires pulling out the pistons. do a compression check first to see whats going on.
Old Jun 7, 2003 | 03:34 PM
keefungliu's Avatar
keefungliu
gray smoke only come when the car is warming up.
Old Jun 9, 2003 | 10:22 AM
crxb16er's Avatar
crxb16er
yah probably because oil is leaking thru somehow when the car is sitting, cars normally smoke less and have less NOx coming thru once the cat is heated up also, might want to have ur catalitic converter checked.
Old Jun 9, 2003 | 11:08 AM
93Integra's Avatar
93Integra
If it only smokes during warm up it sounds like your valve seals are going bad and leaking.
Old Jun 9, 2003 | 12:14 PM
crxb16er's Avatar
crxb16er
yah and when it is resting (car off on that particular valve is open it is leaking oil into the combustion chamber which is burning off when the car is turned on
Old Jun 9, 2003 | 10:06 PM
keefungliu's Avatar
keefungliu
anyone know that i can pass smog or not? can i adjust and pass smog?
Old Jun 10, 2003 | 09:02 AM
crxb16er's Avatar
crxb16er
depends on the engine condition, b4 going thru inspection run a higher octane gas, change ur spark plugs, possibly retard ur timing a little bit to burn out more gas in the combustion chamber, and get the catalytic converter really hot, rev the engine a little bit while waiting if it takes a while, dont turn ur car off, to keep it nice and toasty
Old Jun 14, 2003 | 10:31 PM
ambition's Avatar
ambition
StillDPG
its only gonna get worse. better start savin
Old Jun 14, 2003 | 10:58 PM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
aww a valve job shouldnt cost that much...of course that leads to other things too :chuckles: like rebuilding the whole engine when the new valves up the compression
