how high can D16A6 valve springs rev?
Old May 28, 2003 | 08:03 PM
AwwsChwA's Avatar
AwwsChwA
Default how high can D16A6 valve springs rev?
In my autocross bracket, I'm allowed a modified ECU, which means I can increase redline. But, the block and head have to remain factory. So, how high can I rev a blueprinted engine (not balanced, it's not allowed) on new stock valve springs? My CRX is also my daily driver, so I have to make sure whatever limits I push, they'll allow the car to run hard on the track and run reliably the rest of the time. Thanks
Old May 29, 2003 | 12:05 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I'm assuming you have to run a stock cam? If your stock cam isn't making any power past your stock redline, I don't see the point in revving any higher, unless it allows you to stay in the same gear throughout the course or something.
Old May 29, 2003 | 02:03 PM
qtiger's Avatar
qtiger
Assuming you are making power at that point (inspy covered that so I'll shut up), I might take it up 200 RPMs or so.
Old May 30, 2003 | 06:57 AM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
in my D16a6 i redline up to 6700-6800, i notice more power then... my filter is just screeming also... don't go any higher, you'll notice shit for power then... 6800 is the HIGHEST i would go.
Old Jun 4, 2003 | 01:07 PM
jung4g's Avatar
jung4g
Asianalize your car
In the new super street, there is an article on cams. The issue of needing new valve springs came up, and one expert stated they've run mild race cams in honda engines up to 10,000 with stock valve springs.
With a stock cam, assuming you can fuel it consistently, remember, stock fuel maps wouldn't run above redline... you should be fine to at least 7k, don't underestimate our hondas. But if you have modified ecu all is well. As for daily driving reliability, if you aren't revving to 7 all day long, you should be fine with a higher rev limiter...
Jung
