AEM CAI or short ram?
Old May 17, 2003 | 07:01 AM
slkstr2's Avatar
slkstr2
Default AEM CAI or short ram?
I'm debating whether to get a CAI or short ram intake for my JDM B18c. I plan to keep it stock so I thought maybe go w/ the CAI for more gains? However, I'll lose low ends right? I've had it on a GSR motor and that was the case.
Old May 17, 2003 | 10:02 AM
spooncivicb16b's Avatar
spooncivicb16b
you shouldn't really lose any low end with a cold air intake
Old May 18, 2003 | 07:29 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Errr...you may suffer a bit on throttle response with a CAI versus a short-ram. The overall gains more than make up for it however.
Shingo
Old May 19, 2003 | 11:08 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
I had a short ram for about a week and then went with the CAI and there is a slight, (read miniscule) difference between the two. The CAI does have the edge.
Old May 19, 2003 | 12:28 PM
BonzoAPD's Avatar
BonzoAPD
any power difference from the stock intake? If so where?
Old May 19, 2003 | 12:32 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
On my butt dyno it seems that there is an increase once I hit VTEC and going from 6000 RPM to 8000 RPM is a lot faster.
Disclaimer: My butt dyno may or may not be accurate and the perceived gains may only be in the head of the vehicle owner!
Old May 23, 2003 | 09:21 PM
kepani's Avatar
kepani
what are you expecting out of the intake? i ask you this because i used to have an aem cai and have reverted back to the stock air box.
for one, there is a chance - albeit minor in southern california - of hydrolock (sucking of water into the motor) if there is rain. i was paranoid about this *everytime* it rained and it was not worth it to me. second, you will notice a loss of throttle response in the low end of the rpm range. however, when vtec is engaged/engaging, the gain it slightly noticable.
if you are doing mostly daily driving, then the stock airbox is much better. however, if your r sees a lot of track time, the aem is great.
the veterans over at honda-tech.com seemed to have at one point in time owned a cai and have pretty much gone back to their stock air boxes because of these reasons.
having said all of this, do as you choose ...the aem cai is a great intake; depending on your goal(s).
good luck!
Old May 24, 2003 | 12:09 AM
slkstr2's Avatar
slkstr2
I notice a whistling noise when accelerating when using a short ram or CAI. What causes this whistling noise?
Old May 24, 2003 | 07:50 AM
ur31337's Avatar
ur31337
Colby
The conical filter
Old May 24, 2003 | 08:07 AM
slkstr2's Avatar
slkstr2
So how do I get rid of this whistling?
