wutever
Old May 4, 2003 | 12:30 PM
JustChilln345's Avatar
JustChilln345
Default wutever
LS= stronger block, better torque, lower compression ratio (good for turbo) you will be able to run higher psi wth the LS...
GSR= weaker block (it will prolly crack before the LS), higher compression ratio, which means less psi, unless u dump a shitload of money into it for tuning (and i mean FINE tuning), the higher insurance would make somewhat of a diff. maybe not for some
basically you can put less money into an LS and get just as good of not better results. the only agrument i can think of would be a smaller turbo in either car so that it will spool up faster and give you a little bit better edge at the beginning of your run...thats pretty much all i have to say about that...
Old May 4, 2003 | 12:31 PM
JustChilln345
F U C K...i cant believe i just did that...hopefully no one notices my little screw up
crucial Si's Avatar
crucial Si
Banned
damn...this crap wont end in here...
Old May 4, 2003 | 12:47 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Bringing this up again lol?
A LS is cheaper to build up.
A turbo GSR at 8 psi will spank a LS running 10 psi.
Get whatever you can afford. This thread is going to be locked very soon.
Shingo
Old May 4, 2003 | 12:57 PM
dubcac's Avatar
dubcac
I
A GSR at 8psi will be about equal to an LS at 10psi on average
Old May 4, 2003 | 02:31 PM
XSrcing's Avatar
XSrcing
you mean wotever.
Old May 4, 2003 | 02:38 PM
RB's Avatar
RB
snitches get stitches
LET IT GO
this subject is so overdone.
Old May 4, 2003 | 03:30 PM
Shingoblade-GSR
Hellsing Agency
Bah humbug. h:
Old May 4, 2003 | 03:33 PM
AP2's Avatar
AP2
Moderator Alumni
Please elaborate why the GS-R block is weaker than the LS block. Please elaborate why the GS-R block is weaker with a block girdle while the LS doesn't have one.
Stop posting crappy one-liners in my forum if you can't back it up.
Old May 4, 2003 | 09:37 PM
ChillOutWayne's Avatar
ChillOutWayne
i cant stand these white trash hill-rods that have nothing better to do than start these worthless threads arguing over things that are PROVEN wrong...move on
