can i prep my car myself?
Old May 2, 2003 | 12:52 AM
EddieK's Avatar
EddieK
Default can i prep my car myself?
i was wondering if i could prep my car myself. up to the primer stage. what do i need to do?
Old May 2, 2003 | 01:37 AM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
i'm fairly certain you can. it would make it cheaper. i would talk to the body shop you're thinking about taking it to, and asking them. you'd probably just have to sand it down, fill any holes you wanted to do, then primer it. find out how many coats you'd need and if you'd have to do any sanding after primering it. i'm thinking about doing it myself too, though i may try to paint it myself as well.
Old May 2, 2003 | 07:30 AM
customxtreme1's Avatar
customxtreme1
apply 3 good coat of primer then wait at least 3 hrs to dry. then spray a black guide coat ( meaning is spray a mist coat over the primer spot) then wet sand with a sanding block. use 400 grits paper. taking out the black guide coat then until smooth.. hope that help
Old May 2, 2003 | 08:28 AM
EddieK's Avatar
EddieK
what should i do before the primer?
Old May 2, 2003 | 01:19 PM
customxtreme1
it depend on the condition of the car. Are u applying body filler? Or just want to primer the whole for a paint job? If u applying body filler then i have to sand it down to the metel then straight the dent out then apply body filler then sand it down... then primer it.. it really depend on what u doin to it let me know thanks jimmy
Old May 2, 2003 | 03:53 PM
EddieK's Avatar
EddieK
thanks 4 helping. yeah i wanted to just do the whole care with no body filler involved. thanks again
Old May 2, 2003 | 05:15 PM
customxtreme1
no problem anytime
Old May 2, 2003 | 07:56 PM
carbon-vtec's Avatar
carbon-vtec
Default !
make sure you wash your car with dish washing soap to get rid of any wax, then was with laquer thinner before primer..
Old May 7, 2003 | 02:22 PM
EddieK's Avatar
EddieK
Default painting side moldings?
i was wondering how i should paint the side moldings.. what sandpaper should i use to sand it? what kinda primer? wut kinda paint? (can i use spray can paint?)
Old May 8, 2003 | 02:17 PM
customxtreme1
used scuff agent and grey scuff pad on the molding.. i depend on the spray can if u sprayin black it's ok... or u can sand it down with 500 grit then 600.. same primer u used for ur car hope that help jimmy
