Need Help on Broken Bolt
Old May 1, 2003 | 07:13 PM
FURIOUSGSR01's Avatar
FURIOUSGSR01
FURIOUSRSX04
Default Need Help on Broken Bolt
I was re-installing my front strut tower bar on my GS-R, and one bolt I tightened it to much, and I managed to break off the threaded thing that the bolt screws on. I tried to hammer out that broken thread but it doesn't comes out. I looked under the wheel well, and I see where it goes in, but i can't seem to get it out. Anybody have any ideas? Thanks..
Old May 2, 2003 | 09:11 AM
Turd_Fergason's Avatar
Turd_Fergason
From the sounds of it you broke off the bolt that attaches your upper A-arm. If that is the problem, you are gonna have to replace the upper A-arm. But that is not too hard to do.
Old May 2, 2003 | 02:56 PM
FURIOUSGSR01
FURIOUSRSX04
its not really the bolt, its the thing that the strut tower bar lays on, then u put the screw on top of it. That broke off
Old May 2, 2003 | 03:29 PM
stealthteg's Avatar
stealthteg
prolly the top of the strut
Old May 2, 2003 | 04:35 PM
FURIOUSGSR01
FURIOUSRSX04
<sigh> no.........its the things where the strut tower bar is held on, then u screw it to tighten it.
Old May 2, 2003 | 04:37 PM
bengeeee's Avatar
bengeeee
Theres always the torch posibility :naughty:
Old May 2, 2003 | 04:44 PM
bengeeee's Avatar
bengeeee
Seriously tho....you can drill it out and put one of those sleeve things in so you can put a new bolt in. I forget what they are called. Do you know if the bolt was #5 case hardened? If so you may need a titanium bit for that. If it was then it would have 3 little dashes forming a Y with spaces in between them on the head that you broke off. My auto tech teach told me about this but i forget what the thing is that you put in the hole once you have destroyed all the threads getting the shank out. Good luck. By the way, you may want to get more opinions on this. Im pretty new to auto tech.
Ben
Old May 4, 2003 | 03:42 PM
bengeeee's Avatar
bengeeee
Did you ever get it out?
Old May 4, 2003 | 03:56 PM
FURIOUSGSR01
FURIOUSRSX04
nope i cant get it out
Old May 4, 2003 | 04:01 PM
dubcac's Avatar
dubcac
I
Time to replace your upper A arm.
