Cel 14
Old Apr 22, 2003 | 11:22 PM
sunshine's Avatar
sunshine
Torqueless Wonder
Default Cel 14
I got a cel code 14, IAV sensor defective/unlpugged.... what should I check?
Old Apr 23, 2003 | 01:41 AM
drift's Avatar
drift
Flaccid Member
check the Idle Air Valve on the intake plenum. make sure the sensor plug is connected and undamaged, wiring is in good condition. if all is good, your IAV is faulty and needs to be replaced. your manual would have told you this.
Old Apr 23, 2003 | 02:13 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Also make sure you don't have any vac leaks or air in your cooling system. Either of those will make it impossible for the IACV to idle the car properly, and the ECM will then think the IACV is faulty.
