What Are Benefits of Dual Voice Coil Subs???
Old Apr 8, 2003 | 04:50 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Default What Are Benefits of Dual Voice Coil Subs???
I hear alot of hype about them so I purchased three Rockford rfp he2 subs. Is there anything out of the ordinary thats good about these subs?? Are dual voice coils that much better than single voice coil subs??
Old Apr 8, 2003 | 06:02 PM
b00gers's Avatar
b00gers
the main difference is its versitility with amps. you can get difference impedances with them (OHMs).
Old Apr 9, 2003 | 02:46 AM
Randy12vp's Avatar
Randy12vp
It all depends on which amplifier you plan on running to them.
Old Apr 9, 2003 | 09:20 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
I have a 2 channel Soundstream 1,000 watts peak.
I forgot the model #.
When wiring them in series,... do I leave one of the speaker inputs alone???
Old Apr 10, 2003 | 03:28 PM
Randy12vp's Avatar
Randy12vp
check out this site to help you out with wiring...
www.rockfordfosgate.com
Nice amp to run your trio of subs.
Old Apr 11, 2003 | 07:50 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
I tried that site first and I got a little confused with their diagrams.
It seems like they have 3 subs wired in parallel going to a 2 channel amp. I tried the same thing and I'm getting alot of "clipping".
I'm gonna try to wire the subs in series and bridge them at the amp.
DO I just leave the second pair of terminals on the sub alone???
Old Apr 11, 2003 | 08:25 AM
b00gers's Avatar
b00gers
tell us what impedance, OHMs, those subs are. and if they are DVC or SVC. i think HE2 comes in SVC?
a DVC sub will have 2 sets of terminals while SVC will have 1 set of terminals on the woofer.
then see if you can find out the specs for that amp or at least a model #.
Old Apr 11, 2003 | 11:04 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
They're rfd 3210 4 ohm subs dvc.
The amp is Soundstream 2 channel, 800 watts, I think.
Model # PIC 880 stable @2 ohms stereo.
When wiring them in series,... do I leave the second set of terminals alone??
Old Apr 12, 2003 | 03:12 AM
Randy12vp's Avatar
Randy12vp
Wire the voicecoils for each sub in series.
Then run all three subs in parallel.
Then you will have a final output impedance of 2.66 mono.
You amp should be able to handle such a load.
Everything (voicecoils and subs in parallel = 1.33 mono).
Old Apr 12, 2003 | 12:11 PM
b00gers's Avatar
b00gers
doing that, should he bridge the amp? i cant find info on the minimum impedance for bridging the amp.
