96 Civic Idles up and down
Old Jun 27, 2002 | 06:09 PM
MiamiFlorida's Avatar
MiamiFlorida
Default 96 Civic Idles up and down
This is a regular 1.6 OHC Sedan. I bought it a month ago. It was parked for 2 weeks without starting the engine. It took me a while to start the engine. After that the idle started to go up and down. hen I put it in park it goes al the way to 1500 rpm which is not normal. It wa running fine before and i didn't do no other mechanical work to it. I checked all the vacuum lines, they're ok. Has anyone run into this problem before?
Please help
javier
Old Jun 27, 2002 | 06:16 PM
Bl@ck's Avatar
Bl@ck
Sinner
did you check your coolant levels... if your radiator is empty the engine will rev like that
Old Jun 27, 2002 | 06:41 PM
MiamiFlorida
coolant level is fine and radiator is full
wha else can i try
Old Jun 28, 2002 | 11:11 AM
AP2's Avatar
AP2
Moderator Alumni
Check to see if your PCV breather is still fine.
chriswillett
92+ Civic/EL & Del Sol
3
Sep 7, 2015 01:30 PM
geo2genls
Engine Swaps, Tech & Tuning
Dec 4, 2007 09:53 AM
IntegraGSR12
2
Mar 30, 2006 11:48 PM
bear66
Prelude
5
May 11, 2004 06:27 PM
crucial Si
10
Jan 10, 2003 11:34 AM
