Subwoofer not working?? HELP
Old Jun 27, 2002 | 05:48 PM
Johnny Tran's Avatar
Johnny Tran
Default Subwoofer not working?? HELP
Okay so my car is done being painted and I re install my amps.
I have two amps, one running the speakers and a seperate one running my subwoofer.
The amp that runs the speakers works but the subwoofer is not working.
I am not sure if the two input wires (red and black) are in the proper input/output.
The 12V red wire is correct, the little blue REM wire is in correct and the black ground wire is in correct.
The subwoofer is hooked up to the speaker wire.
What am I missing?? The amp is getting power but the sub is not playing. Have I forgotten something??
Old Jun 27, 2002 | 06:42 PM
smokedogg's Avatar
smokedogg
does the amp turn on? if not, make sure your ground is clean, and your power wire is not loose or anything....if your amp is on, then check your rca's and make sure you have your speaker wires on correct. I once tried to hook up my speaker wire a different way to my DVC subs and they didnt work, so i put the wires back to normal and everything came back on.
edit: since your using multiple amps and if you have a distro. block, make sure the fuse to your sub amp isn't blown (if your amp isn't turning on this could be another solution)
Old Jun 27, 2002 | 06:59 PM
b00gers's Avatar
b00gers
check all the wiring first...at both ends.
are you sure the wiring in the sub is ok?
Old Jun 27, 2002 | 07:21 PM
Johnny Tran
Okay I am a big newb at Audio and amps and subs.
Usually I dont get involved in this area.
As far as I know:
The amp is turning on because the power light is showing and the red 12v and REM wire both show that there is a current.
The black ground wire shows no current which is good.
Then I have the RCAS, in the back of this amp there is two rows to plug them into:
row one: Line input
row two: Line output
Then the other wire I have is a + and - one which is marked and obviously I am putting the + one in the red hole on the sub and the - in the black hole on the sub.
Still no tunes from this amp and sub, but the amp running the speakers work fine.... I checked again and I am sure I have all the wires??
Old Jun 27, 2002 | 07:37 PM
b00gers's Avatar
b00gers
are the RCAs in the input or output?
Old Jun 27, 2002 | 07:42 PM
Johnny Tran
tried both input and output but no thump thump thumpage yet.
Old Jun 27, 2002 | 08:10 PM
Johnny Tran
If this helps any:
The amp's green light is on but the red light is off
Old Jun 27, 2002 | 08:23 PM
b00gers's Avatar
b00gers
so the amp is working properly.
hmmmm. that leaves the HU, subwoofer, and wiring.
Johnny Tran
Yeah I tried all the combinations I could with the RCAs but no go
Old Jun 27, 2002 | 08:29 PM
b00gers's Avatar
b00gers
how about settings on the deck?
or
wiring on the sub, inside the box.
