Another brake thread, help
Old May 4, 2010 | 04:01 PM
themonsteraria's Avatar
themonsteraria
Boats n hoes
Default Another brake thread, help
Well, I made a serious mistake.
Working on my brakes tonight, nothing special, and I go to re-torque the caliper mounting bolts on the drivers side, and the bottom caliper bolt hole is stripped. It gets a little tight, then it just gets loose again. It's not the bolt, it's the actual caliper.
So here's where I need help: Do I need to replace my entire caliper? Or is it OK to drive without the bottom bolt tightened all the way?
Thanks.
Old May 4, 2010 | 04:03 PM
themonsteraria
Boats n hoes
Actually, I looked at the service manual, and I think I should just need the caliper bracket, right?
http://shop.advanceautoparts.com/web..._677092620___#
Old May 4, 2010 | 04:09 PM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
Yup, should just need the bracket I believe. I wouldn't drive it without it tightened down, though.
just don't use the brakes when you drive :dunno:
Old May 4, 2010 | 04:10 PM
themonsteraria
Boats n hoes
Ok. A bracket is a lot less then a caliper... So thats good news.
Thanks.
Old May 4, 2010 | 04:46 PM
ur username looks like "the monster areola"
Old May 4, 2010 | 06:32 PM
Tark's Avatar
Tark
What car?
Old May 5, 2010 | 06:13 AM
JGordon's Avatar
JGordon
Hah. So it does.
Old May 5, 2010 | 06:44 AM
themonsteraria
Boats n hoes
It's for a 98 Civic LX.
I've got another question. I'm in the process of removing the caliper from the bracket, I removed the 12mm bolt at the bottom of the caliper, and there is no bolt at the top. It looks like some type of pin or something. The caliper won't budge. I've worked on some 5th gens, and the calipers on those usually just came right off.
So what do I do to get the caliper off the bracket? Hammer it off?
