91 acura integra no spark after engine change
Old Feb 8, 2010 | 03:56 PM
prestonracing's Avatar
prestonracing
Default 91 acura integra no spark after engine change
I just changed out engine and transmission in a 1991 acura integra. We went from an automatic to a manual trans. Now engine will turn over but there is no spark. Any suggestions as to why? Cant seem to figure out the problem
Old Feb 8, 2010 | 05:47 PM
Fuse's Avatar
Fuse
Did you use a know good distributor? Do you have another distributor laying around? It is a simple system the ecu sends a signal to the igniter the igniter controls the coil, coil fires the plugs.
Is your cel doing it 2 sec bulb test?
If you need a wire diagram go to www.hondatech.info and search for your car.
Old Feb 10, 2010 | 02:20 PM
Lynxs1981's Avatar
Lynxs1981
Did you swap the ecu for a manual one also?
