Trouble with door wiring
Old Jun 24, 2002 | 09:31 PM
D16Y8's Avatar
D16Y8
Default Trouble with door wiring
I have a 99 Civic and ran wiring to the doors through the stock rubber tubing. Using a Dremel I made a small notch on the door hole, and a small notch on the harness plug. Now the door does not have any power to it. I tired wiggling the plug and it fixed the problem but failed again.
I was wondering is there any suggestions I could try before buying a new door wiring kit.
Thanks
Rob
Old Jun 24, 2002 | 09:38 PM
arch iceman's Avatar
arch iceman
Check to make sure it is seated right and connected. Its a molex type plug so it may just be lose. Worst case is you cut into a wire and will have to repair the wire or replace the connection.
Old Jun 24, 2002 | 10:01 PM
D16Y8's Avatar
D16Y8
thanks arch!
I'll follow your idea and check the connections. I will also make the notch deeper so it does not block the connector.
Rob
*hybrid
92+ Civic/EL & Del Sol
4
Mar 2, 2006 10:19 PM
trex_tegra
6
Oct 30, 2004 05:50 PM
Quick Silver
6
Jan 10, 2003 06:26 PM
