Offset question
Old Mar 11, 2003 | 03:11 PM
Diabolik's Avatar
Diabolik
Has an M3 now...
Default Offset question
I did a search, but everyone seems to be up in the air on this.
Getting Volk Gram Light 17x7.5's with a 205/40/17 tire.
I dont want to rub
What offset should the rims be? I don't know a lot about this. Is +43 good or should I do +45?
Thanks
-Diabolik
Old Mar 11, 2003 | 03:37 PM
Diabolik's Avatar
Diabolik
Has an M3 now...
I think the 17x7.5's only come in a 40 mm offset. With a 2" drop am I in trouble here (rub)?
-Diabolik
Old Mar 11, 2003 | 03:57 PM
antarius's Avatar
antarius
Large Member
Yes, you will rub.
You want at least a +43mm for your Integra.
The higher the positive number, the farther IN the wheel is (I.E +45mm is farther IN towards the frame than +40mm)
In any case, I have 17x7.5's and they're +45mm's, I don't rub, but if they were +43mm's it'd be very close and if they were +40's, I'd most definitely rub.
Old Mar 11, 2003 | 04:08 PM
seiya's Avatar
seiya
I believe I have 43 offset on my 17x7.5 (volks also). No rub, but the rears are very close to the control arms. Lowered 1.75
Old Mar 11, 2003 | 04:40 PM
Diabolik's Avatar
Diabolik
Has an M3 now...
Anyone else?
What about spacers? Where can I get them if I need them? (or should I use them?)
-Diabolik
Old Mar 13, 2003 | 04:32 AM
teg_fan's Avatar
teg_fan
I like integra's
would it be ok to have 17x7's with a 40mm??
Old Mar 13, 2003 | 07:31 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Read this: http://www.tirerack.com/wheels/tech/offset.htm
If you use a spacer you effectively lower the offset. For example a 5 mm spacer on a +45 wheel gives you an effective +40 offset.
Old Mar 13, 2003 | 10:29 AM
teg_fan's Avatar
teg_fan
I like integra's
What exactly is offset? Would a +40mm wheel make the wheel 40mm closer to the outside of the car, or 40mm close to the inside of the car, or am I completely off?
Old Mar 13, 2003 | 01:13 PM
antarius's Avatar
antarius
Large Member
A +40mm would make the center of the rim sit FARTHER out from the center of the car (meaning the wheel would stick out more -- like those mexicans with their 13" daytons and like +20mm offsets) than a +45mm would sit.
Old Mar 13, 2003 | 05:18 PM
teg_fan's Avatar
teg_fan
I like integra's
So, it basically gives you a wider stance or do I have brain problems?
