Offset question
Old Mar 13, 2003 | 08:19 PM
antarius's Avatar
antarius
Large Member
Well, sure it gives you a wider stance. I guess.
But it also isn't ideal.
Look at my signature, that's a 17x7.5 with a +45mm offset. If I had a +43mm offset, I'd be rubbing.
Old Mar 14, 2003 | 03:04 AM
Diabolik's Avatar
Diabolik
Has an M3 now...
I guess I may have to stiffen up the shocks (adjust the yellows to be stiff) and may have to roll the fender.
What abou 16x7's with a +42 offset? Would they rub?
-Diabolik
Old Mar 14, 2003 | 04:34 AM
teg_fan's Avatar
teg_fan
I like integra's
I don't understand why a +40 would stick further out than a +45, I thought it was just the placement of where the hub connected to the outside of the rim ex: stock(standard, not alloy) rims are like in the middle and aftermarket ones are more towards the outside it seems.
Old Mar 14, 2003 | 09:22 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
This is a wheel offset calculator: http://toy4two.home.mindspring.com/offset.html
So you enter in a 7.5" wide rim with a +45 offset, and a 7" rim with a +42 offset. According to the calculator, the 7" +42 wheel will have 9 mm more clearance with the shock housing, and 3 mm more clearance with the outer fender. Quite handy.
Think about it this way: the higher the offset, the further the wheel gets "pulled in" towards the car.
The offset is the distance between the hub mounting face and center line of the wheel. The link I posted above should give you a decent explanation of what exactly it is.
Old Mar 14, 2003 | 10:01 AM
Diabolik's Avatar
Diabolik
Has an M3 now...
Ok, cool. SO what is the stock Integra rim? I know 6" but offset?
-Diabolik
