Uhohh, RPM q.
Old Mar 4, 2003 | 08:20 AM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
Default Uhohh, RPM q.
I was driving Jens RSX around town on our way to look for a job for mua, I pulled out of the exit from campus in first, and rip it open full throttle. I come to about 7700 RPM's and it started to bounce but didn't hit redline? Ofcourse I only let it happen like two or three times cause I wasn't prepared for that. Why was this? This was the first time it ever happened, anybody else had the same experience?
Stupaad me, did it while the engine was cold for the most part, it had maybe built up a little heat, like one notch from cold. Help, need this answered concerned I am.
Old Mar 4, 2003 | 08:41 AM
incublinkus's Avatar
incublinkus
JDM Fan Boy
SWEET! she lets you drive it?
Dude doesn't it Redline around 7700? - or is it 7900? it was probably just the fuel cutoff if I am understanding you right...factory tachometers arn't always that accurate...having it off by 200 rpm isn't complete abnormal...
Old Mar 4, 2003 | 08:52 AM
94civicEX's Avatar
94civicEX
I got worms.
I'm not sure on any numbers, but if it was cold...you probably shouldn't have been hauling ass .
99 Integra GSR
06 TSX
duck squad member #00003
Old Mar 4, 2003 | 10:14 AM
THEOLDMAN's Avatar
THEOLDMAN
Checking it twice
Redline on the typeS is 7900 but the rev limiter doesn't kick in until 8200/8300. If the car isn't warmed up enough the ECU won't let the revs get into the VTEC range at 5800 RPM. Sounds like you may have hit the limiter, and that doesn't do anything but shut the fuel supply down to drop the revs. But when you take it in to service it, the ECU will tattle on you to the mechanics if they do any computer diagnostics.
Old Mar 4, 2003 | 01:04 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
OLDMAN is right. The ecu won't let it rev that high unless the motor is warmed up. I am guessing you didn't notice the vtec kick in when it happned.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Mar 4, 2003 | 05:13 PM
honda_pilot
DeeCeeFo'
Thanks for the response guys. You are all probably right.
(1) It was mostly cold, ECU probably cut it
(2) Come to think of it, didn't really notice it but VTEC was certainly not as pronounced as usual...good point.
(3) The tach prob isn't 100% correct but like stated above we've had it to over 8k so, the ECU allows at least to 8100 rpm.
Incublinkus, between us and some other peeps, yes she lets me drive. But it basically stays in our group of friends, you KNOW her dad can't find out cause insurance purposes and he'll flip...'aight?
Thanks again.
Old Mar 16, 2003 | 06:34 PM
neout's Avatar
neout
your cam timing could be off.
Old Mar 16, 2003 | 07:19 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Ah, so refreshing to see a fellow pessimist
Old Mar 17, 2003 | 12:42 PM
NSBTypeS's Avatar
NSBTypeS
MMM MMM Bitch
When the car is cold, so is the oil, so the cams wont activate when it hits the VTEC range. At a standstill teh car will not let you rev past 5500, cold or warm. Id becareful, you could damage somethin.
