Hestitation in 1st/2nd starting out...EGR?
Old Feb 9, 2003 | 07:58 AM
caylan's Avatar
caylan
Default Hestitation in 1st/2nd starting out EGR??
Usually occurs after starting out & below 2300 rpm.
I spoke to Pat Goss, the local auto guy on radio & he said it's an gunked up EGR that needs to be carefully cleaned out (esp. since it's over the oil pan??) within the manifold.
Sorry but what the heck does that mean?
Can some techs explain please so I can get this fixed.
Thanks!
Old Feb 9, 2003 | 08:35 AM
p'sH23Acoord's Avatar
p'sH23Acoord
Your egr (Exhaust gases Recirculation) recycles some exhaust gases back into the intake to reduce emissions. ususally after a period of time the egr gets clogged up. Look for a connection between the exhaust and the intake. That should be the egr. Simple remove and clean out. But have fun that stuff is dirty and hard the remove.
Old Feb 9, 2003 | 09:08 AM
caylan's Avatar
caylan
I changed it above to EGR. Thanks for advice!
Old Feb 9, 2003 | 08:47 PM
preylude99's Avatar
preylude99
caylan, let me know if that solved your problem........
Old Feb 10, 2003 | 03:00 PM
caylan's Avatar
caylan
I've heard that cleaning it is tricky esp since the stuff can get into your oil pan& cause problems.
But how can that be if you are removing it from the engine?
Am I mistaken?
Old Feb 10, 2003 | 04:09 PM
JiggaFan's Avatar
JiggaFan
PIMP-strollin' on 'em!
I was told to change my engine oil after cleaning the EGR ports. I did mine yesterday. Haven't really noticed any change in low end performance--it still sucks! Still kinda stuttering and missing even. Maybe all that will change when I finally get around to changing the timing belts.
Old Feb 11, 2003 | 07:13 AM
caylan's Avatar
caylan
Default timing belt change w/ EGR?
How many miles on your ride for you to have to change timing belt?
Cause I was suspecting the same w. mine if some1 hadn't mention EGR.
Old Feb 11, 2003 | 07:36 AM
JiggaFan's Avatar
JiggaFan
165k miles on the original timing belth:
Old Feb 11, 2003 | 01:53 PM
caylan's Avatar
caylan
Default That is pushing it!
Whoa!
Old Feb 13, 2003 | 04:03 AM
wilsel's Avatar
wilsel
woah!
Werd! You like to live dangerously huh? Change it ASAP!
