computar halp v wont boot
Old Jun 3, 2009 | 01:16 PM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
Default computar halp v wont boot
so this kid ive built a computer for is on his 3rd mobo.. originally we tried a new psu when the first mobo wouldnt power up, and the second mobo fried, so for this 3rd replacement i put the original psu on and flipped the switch. green light is on on the mobo, but when i pressed power, nothing happened. so i played with it a few more times and got it to start. turned it off to try again, and now it wont start. i took apart the power button assembly incase the external button wasn't making contact with the actual switch, but its still not powering up.
any ideas?
Old Jun 3, 2009 | 01:20 PM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
would also like to point out that holding the power button in while it was on would not turn it off, so i don't think the psu or mobo would be damaged..
Old Jun 3, 2009 | 01:26 PM
BetterBob's Avatar
BetterBob
Nobama
Check your video card if it's not onboard.
DarkStarr's Avatar
DarkStarr
Shake n Bake!
its in. what am i checking for?
Old Jun 3, 2009 | 02:29 PM
Red X's Avatar
Red X
x pǝɹ
Is it possible that the pin for power is loose and jiggly?
does the fan turn on when you push the power button?
Old Jun 3, 2009 | 05:10 PM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
well the power button was bad and now the reset button = power button.. but now its not booting up properly. updates later.
Old Jun 3, 2009 | 05:12 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Build it right the first time.
Old Jun 3, 2009 | 05:15 PM
BetterBob's Avatar
BetterBob
Nobama
Test a known good video card.
Also, pull all ram except for the first slot. if the same thing, use a different stick in the first slot only.
Some mobo's dislike some ram... it happens
Do you get a post code at all? (the long and short beeps)
Old Jun 3, 2009 | 05:36 PM
BetterBob's Avatar
BetterBob
Nobama
Also, as to the power button issue.
If you know where the pins for power are, disconnect them, and use a knife to jump them. It takes the switch out of the equation.
I did this when my nephew learned to push the button on my computer. Just have to open my knife and tap it for a second for boot.
Old Jun 3, 2009 | 05:39 PM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
all MY builds work fine h:
this is for someone else
Bob, I'll address your posts in a bit
