B16a overheating!
Old Jan 24, 2003 | 05:58 PM
The Bum's Avatar
The Bum
Black people go wooooo
Default B16a overheating!
Ok heres the background:
- JDM B16a2
- 1 piece thin head gasket
- Its in a 96 civic coupe
- Stock radiator
- The radiator cap is replaced
Why would it be overheating all the time? Its not excessive, but it barely overheats....
Old Jan 24, 2003 | 06:23 PM
dubcac's Avatar
dubcac
I
Leak in the coolant system? How's your coolant level? Air in the coolant system?
Try flushing the system and refilling/rebleeding it.
Old Jan 24, 2003 | 08:39 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You're not losing any coolant, are you?
Old Jan 25, 2003 | 09:20 AM
The Bum's Avatar
The Bum
no, the coolant isn't going away. What happens (forgot to mention this) is that when he pours in the coolant, most of it goes straight to the overflow. We dont think that there is so much in there that it would need to go to the overflow.
Old Jan 25, 2003 | 01:30 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
So you're not *losing* any coolant, but it's getting displaced out of the ratiator and into the reservoir? Sounds like a blown or non-sealing headgasket to me.
Old Feb 25, 2003 | 05:50 PM
civicon19s's Avatar
civicon19s
Holy **** are you serious?? I am experiencing the exact same problems!! What the hell??? Is there anything else that could be causing this and if not, WHY would it be the head gasket? Thanks
Old Feb 25, 2003 | 05:56 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If the ehadgasket isn't sealing, compression from the cylinder(s) will leak into the cooling jacket. Since the cooling system is sealed, that extra pressure has nowhere to go, but past the radiator cap and into the reservoir. If that happens for a long enough time, it'll displace enough coolant to the point where your engine isn't sufficiently cooled, and it overheats.
Old Feb 25, 2003 | 06:27 PM
civicon19s's Avatar
civicon19s
Insyral, that is EXactly what happens... then the resevoir OVERFLOWS! Also, when i go to dump the resevoir, there is milky browish-black sludgy stuff at the bottom of the tank. Could this be oil leaking into the coolant?? help please! The car is about to go to Daytona and i need to be able to drive it back to Atlanta....
Old Feb 25, 2003 | 08:44 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
That could be oil mixing with your coolant. Sometimes if you let the engine idle with the radiator cap off, you can see bubbles in the coolant, but not always. You could try a compression test, but when my headgasket was blown, my compression numbers were fine, and my reservoir only overflowed when i boosted.
Old Feb 25, 2003 | 09:15 PM
civicon19s's Avatar
civicon19s
yeah the car actually runs pretty well! Pulls just fine... ive just noticed coolant leaking in the car (floorboard) also.. could that be related to the pressure buildup maybe?
