tach won't work after swap
Old Mar 28, 2009 | 12:29 AM
SHUA619CIVICSI's Avatar
SHUA619CIVICSI
1991 CIVIC SI
Default tach won't work after swap
hello there,i just finished my swap and my tach wont work it dont even move at all.ive looked over every thing and cant find out why.the speed omater works just not my tach...so if any of you can tell me something i have might overlooked i will apperceate it
Old Mar 28, 2009 | 04:42 AM
Tedmond's Avatar
Tedmond
check your tach wire. the tach wire in the engine bay will be towards the left side of the tower strut. Its a 2pin connector with a rubber boot on it. If you did a swap, run a wire from the cluster through the firewall, and tap into this wire. this will ensure the tach will work.
Old Mar 28, 2009 | 11:52 PM
SHUA619CIVICSI
1991 CIVIC SI
that sounds confuseing im going to look in my book and see what your talking about. the swap was just a stock replacement zc sohc so the wires should just be the same do you have any pics of this wire?
Old Mar 29, 2009 | 07:04 AM
Tedmond's Avatar
Tedmond
i dont have any pics, but its fairly simple to find. It will often be on the left side of the engine bay at the strut tower. It also may be on the right side. BUt if you did a direct swap, make sure you didnt miss a connection.
