Help on an old Accord
Ok, I would appreciate any help I can get. I hve a 1988 Honda Accord LXi and it has been sitting up for a couple of years. Now, due to Honda quality I guess, after putting a new battery on it and cleaning it up a little bit, it started right up, no problem whatsoever. Now, what I do have a problem with is the back tail lights, they constantly stay on. Even when the car is off, as soon as you hook the battery to it, they come on and stay on. It is all the lights in the back and the brake light thing in the back window also. I am just wondering if there could be any certain thing wrong with it or if it might just be a short somewhere and will have to bring it to a shop to find out where at exactly. Also, can anyone tell me how to get the front passenger side door open because my handle broke off on the outside and the one on the inside evidentally came loose somehow and now I can't get the door open. Any help is appreciated.
Unhook the battery for about 5 minutes then put it back on it should reset things.. If not I'd try replacing the fuses. Those are all cheap suggestions.. If not get a Haynes Manual $20 and look for a relay that could be bad..
Originally posted by EliteAccord
Check the fuses for the light before trying to troubleshoot the wires.
Try the local junk yard for the broken parts to your lock
is there a switch on the break that turns on the lights? i know they are on some cars, and i know the lights will go on if the car is off and you press the breaks.. so maybe that switch is stuck..
i saw it on a '83 chevy.. so i could be wrong
Also, thanks to everybody else too.
searched the forums (as i have a 86 accord lxi and the tail lights wont turn off) and found this thread
its been a great help, but i have a couple of questions 1. what is and or where is the little stopper he is talking about and would it apply to a 86 accord his was a 88. 2. can you tell if a fuse is blown with out taking it out of the fuse box and any other ideas would be greatly appreciated. the car has been running great for the last year and this just happened out of the blue today thanks
They sell fuse testers really cheap at auto part stores, and they bring a bunch of extra fuses. You test them, if they are bad, the tester has on the other end something to help pull them out easy, and you'll have the replacements for it.
