Honda Install Problems
I have a 92 civic hb with a problem. ive got a blaupunkt phoenix sqr 29A cass deck. currently i am running sony explod fronts, and pioneer rears. regardless if i turn up the bass even halfway everything distorts. should i upgrade the wiring from the radio? im thinking of just replacing the radio but i dont want to have the same problem with the new one...
and it has front and rear preamp outputs. i have a 350w concept amp that is running 2 reactor 10' subs... i believe 200w rms each. i have the amp hooked up to the rear preamps. even if i tune the gain to the deck and then mess with the bass boost they get very distorted. i had an old road gear deck in my last car and that worked beautifully for $30!!!! any ideas? i know my wiring is correct for the sub and im using rca wires that can handle up to 1000w currents. im also running my 4ga power wire on one side of the car, the remote and rcas on the other side.
please help!!
please help!!
please help!!
please help!!
) I was driving home from work and had my beat going strong. After about 5 minutes of beating out, everything became staticky, until I turned the volume all the way down to a whisper, anything louder than that and it was pure staticky as hell. I could not figure out the prob for the life of me. I though I had blown my pre outs cause my deck only had a single set of 2 volt preouts and I was running 2 amps off the single set. After ripping my deck out, bench testing it, hooking it back up, still having the same problem, exchanging it and upgrading to a better deck(w/2 sets of preouts
) and still having the same problem. I said f*ck it, I know the fuse isn't blown cause my amps are powered up, but what the hell, let me check the damn fuse anyways. I looked at it and it looked like a Ruffles potato chip(hella wavy) still intact, but wavy. I put a new fuse in it and problem solved. I was mad that I didn't get that done in the first place, but I ended up getting a better deck(thanks Best Buy:thumbup: ) out of it so I just had a bruised ego for a minute.Cliff Notes: check ur fuse coming off the battery and replace it if it's not flat like it's supposed to be
the amp fuse is fine. its an 80W fuse. the thing is huge. if it was blown it still wouldnt solve why the explods and pioneers running off the deck sound like ****. but thank i didnt think of that and i ran out to look at all my fuses.
ok i tried that. i left the front speakers plugged in, and i plugged the amp into the rear rcas. same thing. i also unplugged the fronts and tried both the front and rear outputs. still crap. im gonna switch the deck in the morning to my cheapo walmart deck that works so great in my crx and see if that solves the problem... it powers 4 pioneers nicely with a 250w amp. worst case ill just move the whole setup to the civic. sell the blau deck...
when i bought the car it had all 4 blown speakers, so i replaced them. i got the amp and subs to work properly.... just cant get the mid-highs correct now. when i wake up ill switch stereos. i did look at all the fuses. they look great considering i added the sub and amp 3 days ago...
